Differences between single and dual cats
Old Nov 11, 2000 | 11:24 AM
Troy 85Z's Avatar
Car: 85 Z
Engine: Edelbrock Injected 350
Axle/Gears: 3:42 LS1 Posi
I have the single cat system on my 85Z but wanted to go to the dual cat. I'll be getting headers and cat back soon. Is there any special mounts I need or is it to much of a hassle to convert? Are there be any other problems I would run into? Thanks
Old Nov 11, 2000 | 04:36 PM
GH6801's Avatar
Dual cats is a good way to go. You probably are, but make sure you get High Flow Cats. Also forget about that cat back because those are set-up for exhaust systems with y-pipes. Just get two mufflers. Right now I'm running dual hi-flo cats, edlebrock TES headers, 2-1/2 dia pipes, and two dynomax mufflers. I haven't had any problems with it, some ******** tried to tell it was illegal but I've had it done by a professional, had it emissions tested, and it passed everytime and the guy told me it ran really clean everytime.
Old Nov 11, 2000 | 06:33 PM
Troy 85Z's Avatar
Car: 85 Z
Don't SLP headers come with the y-pipe? I was trying to get a complete bolt in system. If I get the headers, y-pipe, cats, and cat back I should be able to just bolt everything right in without much modification, at least that's what I hope. I know that there is a small indention in the floor board under the passanger side for the single cat system, but where is each cat located with the dual cat system? I don't want anything hanging under the car. If anybody has pictures or a link to pictures of a dual cat car I kinda want to see where everthing is located. Thanks
Old Nov 11, 2000 | 09:11 PM
1989CamaroRs's Avatar
some states will not let you have 2 cats if the car came with one, i belive in virginia you can actually get a fine.....pretty dumb
Old Nov 11, 2000 | 09:25 PM
Troy 85Z's Avatar
Car: 85 Z
I shouldn't have a problem switching legally. There are no inspections or emmisions testing here.
Old Nov 12, 2000 | 03:02 AM
Black Beauty's Avatar
Car: 90 Camaro RS
Engine: 305 TBI
you WILL have ground clearance problems with a true dual exhaust. plain and simple. it is all custom work. nothing is bolt on when it comes ot making your car true dual.
Rick
90 Camaro RS 305 TBI
400 small block, Hooker 1 3/4 super comp long tubes, Random Tech Cat, Hooker aero chamber cat back on the way!!
TH700-R4 with Trans-Go shift kit
MacEwen Motorsports White Gauge Overlays
K&N Filter Charger (wooohooo)
GTS Headlight and Taillight covers
5% Limo Tint all around
Classic White Chevy Bowtie sticker on rear window
Man if my camaro were a rice-rocket all those mods would give me what...easily 50-60 hp!!!
Old Nov 12, 2000 | 03:20 AM
Omar's Avatar
I dont think he wants a true dual exhaust. He just wants to get the dual cats that came stock in some 89 and later Z's. Even if you need to fabricate new hangers and such, any competent exhaust shop can do that for you. Just go searching for the pieces at a junkyard or on ebay.
1989 IROC-Z 5.7L
Old Nov 12, 2000 | 11:20 AM
Troy 85Z's Avatar
Car: 85 Z
I don't want dual exhaust, just the dual cat y-pipe design that came on the later cars. I assume this is possible, has anybody else done this? Are there any things I need to look out for or avoid? Thanks again
Old Nov 12, 2000 | 02:38 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Yah its possible. My dad will be converting to dual cats when he changes his TBI RS to TPI this month. If you're getting headers and a y-pipe too, then just get the ones for a dual-cat setup and add your new cats in. You will also need the trans-to-cat hanger, that driver's side cat bolts to. (When I say driver's side cat, I dont mean there is a cat on the driver's side. They're both on the passenger side. I mean the cat that is on the driver's side, of the two. Its closest to the transmission, and there is a hanger that attaches it to the trans. Just wanted to make that clear. )
Here's a pic of that hanger and my dual-cat setup: http://24.1.139.249/images/101400/DCP_0018.JPG
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Nov 12, 2000 | 07:44 PM
Troy 85Z's Avatar
Car: 85 Z
Where can I get that hanger? I have a 5 speed, would it be different from the auto? I don't really want to fab anything so if anybody know where I can pick up all of the correct hangers (besides the dealer), let me know. I was planning on doing this all myself so I'll need everything before I start. Thanks
Old Nov 13, 2000 | 01:39 AM
Kevin91Z's Avatar
Uhm... your local dealer, maybe? Or Dal?
Old Nov 13, 2000 | 11:34 AM
Pino91Formula's Avatar
If you want to buy the whole dual cat setup with Ypipes co to discount converters http://www.discountconverter.com/
the part # is 4153
its about $380 and they are hiflow catco cats, i have the same setup waiting to be put on my car , but they are great way to go dealer cost is like 700 or so
Pino
91'Formula
LB9 305 TPI 5-speed
http://www.geocities.com/MotorCity/Garage/5654/mur91.jpg
Brinkkl2000
Aug 4, 2018 08:29 AM
onefreakz
May 14, 2018 12:15 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
chazman
Aug 22, 2015 02:01 PM
Jlanz55
Aug 17, 2015 07:15 AM
