will open headers hurt my motor?????
I just got my cat gutted and i have an exhaust cut out on it that i got a long time ago but im afraid that opening the cutout and running the headers open. will the open headders screw up my car?????? any help would be great.
Thanx,
Ross
keep the stang's far behind u and the cops even farther
Thanx,
Ross
Hell NO! Jet that baby up a little richer and pick up a couple tenths at the track!
84 Camaro ZZ4 with HOT cam. 1.88 60' (12.98 @ 105MPH E.T.)
Other Mods: You name it and I have probably changed it.
91 Firebird 5.0L TBI
ASE Certified CHEVY DEALER Auto Tech
LIVE AND DIE BY THE ALMIGHTY BOWTIE!
Neighbors--------Ha Ha Ha Ha Ha Ha Ha! ROTFLMAO!!!!
Thanx aolt guys! im going out to take the cut out off right now and listen to my neighbors yell like sons of bitches.
Later,
Ross
Later,
Ross
While running open headers may not hurt your engine, you could actually end up losing a little bit of torque and gaining horespower. Naturally aspirated engines require some exhaust back pressure to function properly. But then again, you won't notice a large difference, and it sure would be fun pissin off people like that!!!!
Car: 90 Camaro RS
Engine: 305 TBI
ok i want a cutout too..but where to install?? does it go before the cat or after it..before muffler ??? where?? thanks rick
Rick
90 Camaro RS 305 TBI
400 small block, Hooker 1 3/4 super comp long tubes, Random Tech Cat, Hooker aero chamber cat back on the way!!
TH700-R4 with Trans-Go shift kit
MacEwen Motorsports White Gauge Overlays
K&N Filter Charger (wooohooo)
GTS Headlight and Taillight covers
5% Limo Tint all around
Classic White Chevy Bowtie sticker on rear window
Man if my camaro were a rice-rocket all those mods would give me what...easily 50-60 hp!!!
Rick
i put it right after my y pipe comes together i gain 3 tenths in 1/4 mile i highly recommend it motor revs so much quicker with cutout in i crossed the 1/4 at 4800 rpms with it out i crossed 1/4 at 5200 rpms love it man get one
1992 camaro RS
373 10 bolt rearend
ssm sfc's
87 350 TPI
bored 30 over
compucam 2032 with 1.6
482-495 LIFT 214-220 duration full roller rockers
msd6AL
1 5/8 headman headers
2 `1/2 flowmaster exuast
k&n filters gutter air box gutted maf
3 pc under drive pulleys
no emissions no egr etc
custom ED Wright chip
eddelbroc intake base and runners ported plenum
midly ported and polished stock heads
Taylor 8mm wires
B&M mega shifter
gutted maf/airbox
hotchkis lower control arms
3" exhuast cutout
homemade cold air intake
2000 tci stall
700R4 with B&M shift kit
new best ET 13.5 @104.66
1992 camaro RS
373 10 bolt rearend
ssm sfc's
87 350 TPI
bored 30 over
msd6AL
Taylor 8mm wires
B&M mega shifter
gutted maf/airbox
3" exhuast cutout
2000 tci stall
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Mine is after the cats. Here is a pic of it: http://24.1.139.249/images/101400/DCP_0018.JPG
I just open it up at that flange and it sounds awesome! On the previous engine I had, I gained 13 HP and 12 TQ on the dyno after opening it up. I havent dynoed it open with this engine.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.25 @ 107.18 MPH
Southern California
Car: C1500
Backpressure is only good for your low end. The less the better in the high end.
1989 Pontiac Firebird Formula W6S LO3 TBI 305.
1985 Camaro IROC-Z LB9.
Car: 90 Camaro RS
Engine: 305 TBI
kevin...i couldnt see yours...is it a flowtech?? do you think the best position would be b4 or after the cat...i think before. i have a random tech hi flow cat. thnaks...rick
It does'nt have **** to do with back pressure. Smaller pipes help certain cars because of EXHAUST VELOCITY!!!!!!!! A smaller pipe will produce LOW END TOURQE because of, thats right, EXHAUST VELOCITY! Stupid backpressure BS!
Car: 92 RS
Engine: 406 SBC
Transmission: 4R70W
Axle/Gears: Moser/Strange 9" 3.73, spool
If you really want to make it flow, put one in after each header collector, I'm thinking of doing that on mine...
1992 RS
327, Modded TBI, Rebuilt WC T-5 5-speed, PRO 4 15" rims, Nitto's, 3.73's, SLP 1 5/8" headers, and a few other things.
1992 RS
Best would be before the cats, but easiest is after the cats. TGO Supporter
Car: C1500
What if you can't "jet" your car? Or you want to still get good mileage?
-180 degree stat
-Hooker Cat-Back
-180 degree stat
-Hooker Cat-Back
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
bump up your fuel pressure
91 RS W/carbed 350, Vortec heads, performer rpm, Comp cams Xtreme energy 280 grind. BFG Drag radials. 3.42 posi,Corvette servoed 700r4, ****ty stock converter
13.24@104
13.24@104
mdtoren
Aug 16, 2015 05:45 PM
