Please answer Hooker Question
Old Nov 13, 2002 | 01:21 AM
cali92RS's Avatar
Car: White KSwisses
Engine: 5.3L Gen III
Nobody has been able to answer me this question. Why do the hooker 2055's ( the shorty super comps) say they are only for 1986-90 5.0/5.7L? What are the differences between the 1990 and the 1992 exhaust? I have a 92 5.0L and ive been told to get the 2055's, that they will fit my car, but why does it only say to 1990? Im jus a lil tentative about spendind over 300 dollars on something that might not fit.
Old Nov 13, 2002 | 09:10 AM
TBI305Camaro's Avatar
They will fit...A.I.R hookup might be different tho...no wait i know why. The 90-up TPI (what that exhaust is actully made for) had the dual cats. Thats why they say it wont work. But since you dont have the dual cat setup it will work fine. Get those headers, high flow cat, and a hooker catback and be done with it,.
Old Nov 16, 2002 | 03:27 PM
88Bravo's Avatar
Car: 1988 Pontiac Firebird, flat black
Engine: Stock 305 LO3
Transmission: Five speed
Make sure to get them coated or to coat them your self. Take off the black paint. They work great. I didn't have that much of a problem to install. I did it from the bottom on a lift. If you are worried about emmisions, run two high flow cats. That should clean everything out the way you need.
Old Nov 16, 2002 | 03:35 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
does anyone remember that thread with that chrome like coating , that won't turn colors like chrome?? I want to get that done, and can't find the thread.
Old Nov 16, 2002 | 04:44 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
called ceramic coating mark
Old Nov 16, 2002 | 04:48 PM
Car: 99 Formula
Axle/Gears: 342
u jerk, I could have searched for coating, but I didn't know how many would show up, figured I'd ask first.
Old Nov 19, 2002 | 02:31 PM
justadba's Avatar
Car: 88 IROC convertible, 88 Sport Convertible---both RED
Engine: 350 TPI in the IROC, 305 TBI in the Sport
Transmission: 700R4 in both
Say 88Bravo
you said you put on a set of 2055's... Put it on a lift and had no real problem? Did you have to remove any of the air cond stuff and what about the starter on the passenger side?
I know there HAD to be some gotcha's...what were they?
Would jacking it up and putting it on jackstands about 14 - 16 inches up work OK? Don't have a lift at home...but do have a ton of jack stands.
billybob6110
Sep 24, 2016 09:50 AM
Red iroc-z 305
Sep 30, 2015 05:22 PM
tricky1
Aug 23, 2015 01:17 PM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
