Are there any small cats out there?
Old Nov 13, 2002 | 01:18 PM
Jekyll & Hyde's Avatar
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
I am looking to do true duals, but I don't have a dual cat car. I have an 88 IROC.
What I want to do is place two cats side by side where the one is and go the rest of the way. I will be pushing 425+ hp by next summer, when I can finish my engine. I need a good flowing cat that would flow enough for the 4 bank per exhaust tube. Anybody have any ideas?
TIA
Old Nov 13, 2002 | 01:37 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Summit p/n CTO-6006. "Universal, 14 in. long, 2-1/2 in. diameter slip fit inlet and outlet, stainless steel, catalytic converter." With A.I.R. tube (if that's an issue - plug it if not).
1/4" larger ID than factory dual cats, should flow plenty for your power.
Old Nov 13, 2002 | 01:40 PM
I am planning on doing two 2" pipes to dump. I guess I will need to see what the inlet/outlet sizes available are. I don't want to get too big.
Is 14" too long for the area that is there? I figured that would need to be shorter.
Ever heard of a dual inlet/outlet on a cat?
Old Nov 14, 2002 | 12:29 PM
five7kid's Avatar
http://www.jcwhitney.com/item.jhtml?ITEMID=3872&BQ=jcw2
I have no clue what the pipe sizes are.
If you are really going to produce 425 HP, 2" is probably a bit small.
14" is shorter than the factory cats.
Old Nov 14, 2002 | 01:48 PM
Yeah I found that last night, but I wish I knew what size if was. I guess I will call and find out later.
Thanks man!!!
Old Nov 14, 2002 | 02:27 PM
Momar's Avatar
Yes, it takes dual 2 1/4 to equal single 3 so dual 2 is probably to small for the kind of power you want to make. I would do dual 2.5.
Ben
Old Nov 14, 2002 | 02:36 PM
five7kid's Avatar
I think the JCW paper catalog has the pipe sizes for that dual/dual cat, but I don't have one in front of me right now.
mud runner
Nov 2, 2015 07:30 PM
Jorlain
Oct 8, 2015 01:57 AM
Stryker412
Sep 20, 2015 06:59 PM
gta892000
Sep 16, 2015 12:37 AM
Camaro_383
Sep 11, 2015 11:28 PM
