Exhaust leak into interior
Old Jan 19, 2001 | 09:31 PM
Klatt's Avatar
been getting a really nasty exhaust smell in the interior of the car now. as you would think, it gets a lot worse when i step on the gas. it seems like its coming from behind the climate controls somewhere. i do hear hissing from the climate controls when they are on and my heat wont come out of the vents, only ac will...dunno really...
Old Jan 20, 2001 | 01:05 AM
The Rusty Trombone's Avatar
yeah i get that god damn annoying hissing too... only when the cold-hot switch is not all the way to cold and only when im pressing the gas pedal...dont have a gas smell... but i have NO idea what that hissing is... and my heat doesnt work that well... god damn hissing
1987 Midnight Blue Camaro IROC-Z, 350 TPI out of an '88, Accel 8.8 wires, hypertech air foil, flowmaster american thunder 3" dual outlet cat-back... slipping tranny!! (T5 swap next spring!!)
Old Jan 20, 2001 | 09:51 AM
Klatt's Avatar
yah i know aint it annoying. i dunno if it really has anything to do with the heat working or what. like i know on a lot of cars if u have the heat or whatever on and then turn it off u get the psssssssssssssss after its off, but not usually when its on..:-/
Old Jan 20, 2001 | 11:12 PM
Klatt's Avatar
ahhh tonight coming home it was burning my eyes!!!...NOT COOL!!!
Old Jan 21, 2001 | 01:38 AM
XxMoLexX's Avatar
I get the hissing usually when i jus start up the heat or vent, but i turn it on high for a sec and then it stops. Did yours do this in the beginning and progress to a constant thing?
91 3.1 RS.
T-Tops
12" tube in the trunk
16" ROH Rims (Need Center Caps) ROH Rims
Firehawks all Around
Old Jan 21, 2001 | 08:02 AM
Klatt's Avatar
im not sure really, i just sort of all of a sudden noticed it.
Old Jan 21, 2001 | 10:47 AM
jms's Avatar
jms
Are you getting headaches after driving the car for some distance? If so, that is a MAJOR sign of carbon monoxide poisioning.
Park the car until it is repaired. IT WILL KILL YOU!
In addition, does the burning smell resemble wires burning? If so, park the car until you can get someone to take a look at it. Not fun to have your car burn up in front of you.
Just behind the climate control panel, there is a vacuum hose junction that connects to the back side of the panel. Your hiss may be coming from there. If it has a leak(s) it will not properly control the vacuum to the diapraghms to move the doors that re-direct air flow under and through the dash. The air flow will determine defrost or heat or whatever you tell it to, depending on where the sliding control is set and if the vacuum lines are still functional.
This burning to your eyes is not something to mess around with. Ever heard of people committing suicide by carbon monoxide poisioning? That is basically how it is done.
jms
Old Jan 21, 2001 | 09:19 PM
Klatt's Avatar
hehe thnx dude, yah i drive with the windows down and i dont usually drive for more than 15 min at a time max...it usually just smells bad, but that burning eye thing was like whao ok thats not cool....and thnx for the info, atleast i got somethin to go on now. would that make it smell tho?
Old Jan 22, 2001 | 06:13 PM
jms's Avatar
jms
Another possible source for a 'bad' smell could be a leak from your valve covers that drips down on the exhaust manifolds or exhaust pipes underneath the car.
jms
Old Jan 22, 2001 | 09:51 PM
Klatt's Avatar
yah but would that make it get a lot worse as soon as i step on the gas? like instantly?
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
TheExaminer
Aug 26, 2015 04:59 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
