Just thought you would like to know
Old Jan 30, 2001 | 03:04 PM
chevyboy07 91's Avatar
I keep seeing posts where the minimum range dollar amount for headers w/ y-pipe is $300. Well, I just recently got a new set of heddmen shorties w/ y-pipe for my 91 and they were shipped to my door for $210. What's the deal>>>did they screw up w/ my price. It was from Jegs by the way
Old Jan 30, 2001 | 03:15 PM
zupmanZ28's Avatar
Car: 86' Z28
Engine: 355
are they emissions legal?? if so thats one hell of a price...
86 Z28 red,
originally LG4,
new 350, T-5 five speed with new clutch, 3.23 gears, K&N Air Filter (best 35 bucks i ever spent!) Edelbrock Performer intake, crane 272H cam, Edelbrock performer cat- back, KYB GR-2 struts and shocks.
steering wheel.
Future mods:
NOS, Edelbrock TES headers, hi flo cat., 4th gen interior, 6 point roll cage, 3.42 gears
hurst billet/plus shifter, Edelbrock STB, IROC Rims
view my car (movie)
Old Jan 30, 2001 | 04:06 PM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
Onetime, Jegs sent me my STB and then sent a 132.00 check in the mail to me as well. Apparently they thought that I asked for a refund. LoL. FREE STB!
Eric Natzke
91 Firebird 305 TBI
"It Ain't Stock"
http://members.aol.com/j007golden/91firebird.html
For info on certain parts or mods go to the site below
http://members.aol.com/j007golden/modeval.html
Old Jan 30, 2001 | 04:37 PM
ONEFINE8T9's Avatar
damn thats a hell of a deal eric
1989 pontiac firebird
bright red exterior(just repainted)
grey interior
5 spd
305 TBI (stock)
WS.6 formula wheels
3.73 posi rear end
http://members.aol.com/j007golden/Mikey89.html
1985 trans am
factory bright yellow
4 wheel disks
16 inch wheels
305 TPI
power antenna and mirrors
t tops
Old Jan 30, 2001 | 07:31 PM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
In the best impressionation of that jap guy off WWF. "INDEEEEEED!"
Eric Natzke
91 Firebird 305 TBI
"It Ain't Stock"
Old Jan 31, 2001 | 01:22 PM
Well, I asked for the ones w/ no A.I.R. injection tubes and had to weld my own O2 sensor bung in there.
Old Jan 31, 2001 | 02:16 PM
84TransAm's Avatar
Did you get a discount on the headers? Or are u a normal customer? Also, part number please!
--Steve S--
1984 Trans Am 305 LG4, 5 speed
RPO codes point to Recaro version
Daily Driver, Flowmaster 80 Series
Old Jan 31, 2001 | 03:03 PM
TK87TA's Avatar
the headders he speaks of are hedmann # 68470 and the matching y-pipe is # 17470 (i think). jegs and summit both have the headers for ~ $109 and the y-pipe for ~ $99. i emailed hedman's tech. dept., and they are an exact match together, the y-pipe is 2.5" dia. (stock is 2.25" on my car) they are shorties, 1 5/8" primaries, 3 " collector, and have no A.I.R. tubes. they are the headers i'm about to order. check out http://www.headman.com and look at the catalog for any addn.info.
1987 Trans Am
"Tired, old 305"
4 barrel, 2.73 rear
700R4 + B&M stage 2 Transpack
1980 350 Small Block sitting on the stand waitin' for heads.....
Best 1/4 mile time:
16.075 @ 85.52 MPH
Old Jan 31, 2001 | 03:49 PM
He said it>>>>>>they're complete w/ all hardware and gaskets. The only design flaw I found was the y-pipe slip on connector location. The "turn-down" off the driver side header slip fits into the y-pipe right under the oil pan. You can't clamp it there w/o causing damage to the pan so I MIG'ed it as much as I could. About 1/2 way around. However, regardless, there are no leaks whatsover where I half assed this part. This is because it fits into the y-pipe instead of over it.
Old Feb 5, 2001 | 04:47 PM
BretD 88GTA's Avatar
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
TaliNG,
Headers replace the factory exhaust manifolds that bolt to the cylinder heads. They offer increased exhaust flow which gives you some more horsepower. The "Y" pipe mates the headers to your exhaust system.
True dual exhaust on ours cars is a pretty tricky thing. Since they were never designed to have dual exhaust there isn't much room under the car for it. There are some guys on the board though that have pulled it off.
The other thing you have to consider is whether or not your car needs to pass an emissions test. If so, you need headers that have A.I.R. tubes so the factory smog equipment can be hooked up to them. With a dual exhaust system you can forget passing a smog test. No factory 3rd gen evre had it, so legally you can't put it on, and your car will fail a visual inspection. This all applies to a daily driven street car of course.
As for your stock 305, I'd stay away from headers for now. The money would be better spent on other mods. You will find a good cat-back system helpful though.
[This message has been edited by BretD 88GTA (edited February 05, 2001).]
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
David Frans
Oct 31, 2015 08:12 PM
tmellott89
Oct 14, 2015 02:06 PM
Giocio
Oct 1, 2015 12:20 PM
Damon
Sep 26, 2015 04:29 PM
