Dual exhaust
Old Feb 3, 2001 | 12:29 PM
jody92RS's Avatar
Dual exhaust
I know that this is a stupid question but can I put true dual exhaust on my 1992 camaro. The reason I ask is a local exhaust person said that it can not be done. If it can be done can someone explain what I will need to successfully finish the job.
Jody
1992 25Th Anniversary Camaro
305 TBI
5 Speed
Old Feb 4, 2001 | 03:07 AM
burnoutrpm's Avatar
it can be done just saw it on a 82 camaro! but need a pic to give to whoever does my exhaust. because they dont think its possible! but i know better! yes its very possible(2 pipes and flows!) sounds dammmmmn good tooo!
1989 firebird formula
Mods: converted from T.B.I. to a carburator 305 to a 350. Flowmater exhaust,hedman shortie hedders,202 160 (882) heads,.447/.447 lift 222@.050 duration speed pro 327/350hp cam 350 .40 over (356) Edlebrock torker2 and a 600 edlebrock manual choke (1405)
Future mods performer rpm air gap intake (polished) comp roller cam, and way better headsa 400 defintely in the works!
Old Feb 6, 2001 | 08:22 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
The person who owned my 305 TBI before ran into the same problem. Yes it can be done but there is a serious clearence problem. If you plan on doing any suspension mods i would not do a "true dual." I have one pipe that splits into two out the back and it sounds and performs just fine. I would recomend getting a dual cat off another Camaro that was equipt with it. That and the single set up (split out the back though) would be just fine and should still give you plenty of extra horses. Plus the single setup is designed to fit in the groove of the origional pipe, providing the proper clearance. A dual pipe places the pipes outside this groove and greatly takes away necessary clearance. But if you plan on driving roads that are 180 degrees flat, than by all means go for it. I have nose clearance problems as it is and I can only imajine how bad it would be if I had more pipe down there!
Old Feb 6, 2001 | 08:47 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
Yeah, I remeber seeing a true dual. It ran 2 pipes (2.5" I think) side by side and staggered the mufflers in the x-flow position. A single 3" or even the new 4" systems would be alot eisier to work (Thats alot of custom bends&welds) and be just as good IMO.
Old Feb 7, 2001 | 03:13 PM
88blkiroc's Avatar
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
ya, you can do it, but to do it well you need lots of cash and small mufflers. Im planing on doing true dual sometime. Im gona run Brola XR-1 race mufflers cause they are so damn small. i have seen a few pics of ture duals on third gens, both side exit and all the way back, it can be done but you need a good exhaust shop that is willing to work with you. if you want more info on my plan for the true dual on my car email me.
Old Feb 26, 2001 | 11:36 PM
Drufire's Avatar
it is possable, i have a true dual exaust on my 84... you need the right headers, and alot of time to mess with it, cause a exaust shop will not do it, because you can not do it and mantain you cat' converter...
Drive A BowTie And Leave The Suit At Home!
Old Feb 27, 2001 | 02:27 AM
3.1 firebird's Avatar
I dont think most people are going with the true duels for the power alone, but the awesome sound that comes with it.
Old Mar 1, 2001 | 09:44 PM
superz's Avatar
how the hell do u guys do the dual exhasut thang? i just don't get it, how do you have any ground clearance? my iroc sits low as it is. with dual exhaust, how do you drive it with out smashing it going over road kill or something?
Old Mar 1, 2001 | 09:47 PM
Superblue87Formula's Avatar
I'm cheating and going with side-exit exhaust (dual 3") with high flow cats and no mufflers..
Hotrodboba400
Dec 10, 2019 07:07 PM
customblackbird
Oct 1, 2015 04:30 PM
Camaro_383
Sep 11, 2015 11:28 PM
Djmathis123
Sep 8, 2015 08:42 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
