own exhaust
Old Dec 4, 2002 | 06:07 PM
fbody83's Avatar
Car: 1983 firebird S/E
Engine: Built 350
own exhaust
I dropped a new 350 in my 83 firebird and now i wanna get a true dual exhaust system. But i dont wanna spend all the money for it so i was wondering how hard it is to make your own? My friend told me i need a pipe bender and stuff... but i dont know. Can anyone with experience with this give me advice? Thanks.
I'm probably gonna get a custom y-pipe done by some shop then go from there.
Old Dec 4, 2002 | 06:37 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Search for fast3rdgen's post. He has a nice setup.
Old Dec 4, 2002 | 08:48 PM
AFatHippo's Avatar
Car: '88 Camaro
Engine: 355
maybe i misunderstood you, but true dual exhaust doesn't utilize a y-pipe like you said. if you used a y-pipe, youd have a single pipe.
Old Dec 4, 2002 | 09:52 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
It's not to hard but you'd best know how to weld if you're wanting to make exhaust w/o a bender.
Here's how I did mine..
http://www.deadbird.org/anews/index.htm
And a rear shot..
Old Dec 4, 2002 | 09:54 PM
Car: 99 Formula
Axle/Gears: 342
True, I was assumin he meant that if he couldn't do duals, he'd use a Y.
Old Dec 4, 2002 | 11:12 PM
fbody83's Avatar
Engine: Built 350
Yeah, i just wasnt thinking when i typed that, no y with true duals thanks for correcting me
yeah i'll check into the welding, i think my buddy knows how to do that and has access to a shop with one
Old Dec 5, 2002 | 11:33 AM
TZFBird's Avatar
Car: 1988 Firebird, 2000 GTP
Engine: 327
Axle/Gears: 9" posi, 4.11
I am also thinking of doing this, except I am going to make my own Y-Pipe. Going to be 2.5 from heach header into a single 3"
I am just not sure how to mate up a custom Y like that to the stock 3" pipe back from the cat to the muffler? I was thinking of cutting off the very end of the pipe, and welding a flat metal plate to the end, and using one of those short flex pipes between the Y and the pipe back. I just want to be able to take this apart in the future if I need to. Or could I ust weld all this together and be done with it? I just want to be able to disconnect it if I have to. I will also be doing away with the cat.
So, my question is: How can I make my own coupling in the pipe? I'm trying to get this done as cheaply as possible. Tools are no option. I have everything I could possibly need. Any ideas are welcome.
Old Dec 6, 2002 | 07:41 AM
TBI305Camaro's Avatar
PM me I have an entire dual setup for sale for cheap. Very cheap...Its ready to bolt on and hasnt been on the car very long. Car is sitting now so I can take it off and send it whenever it doesnt matter.
Old Dec 6, 2002 | 12:38 PM
TZFBird's Avatar
Engine: 327
Well, I really don't want a dual exhaust setup that bad. Besides, My dad had one on his 72 Duster and didn't like it.. due to the pipes rusting out. Decrease in flow=more water in pipes. I don't need that sort of stuff happening. Plus, I already have the catback bought. All I need to do is make the Y-Pipe and buy some tips. Thanks for the offer though.
Old Dec 6, 2002 | 02:33 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
so dual exhaust systems rust out faster?
Old Dec 8, 2002 | 07:48 PM
TZFBird's Avatar
Engine: 327
that's just what he said heppened. It seems possible to me, but I guess there is always the stainless and aluminized exhaust that they have now. I doubt that's what he had back then.
Old Dec 9, 2002 | 08:04 PM
NJITIROC's Avatar
Car: 1989 IROC-Z
dead bird your ground clearance looks great!
most people with the True duals seem to lose alot of it, but you did well my friend!
zapr
Jul 27, 2018 06:03 PM
PurelyPMD
May 5, 2016 04:57 PM
86White_T/A305
Mar 6, 2016 01:48 PM
1992Z28!
Nov 19, 2015 07:33 AM
david068513
Sep 18, 2015 10:36 AM
