Catco Converter
Old Mar 5, 2001 | 09:49 AM
im's Avatar
im
Catco Converter
Just wanted to know what size converter should I get(3 inch or 2 3/4 inch)from Summit(any one know the part numbers??). I have edelbrock headers and a flowmaster 3 inch cat back. I know they advertise 3 inch exhaust. I have my original gutted converter on my car know. What is the correct size to buy????
My car is an 88 iroc 350 TPI
Old Mar 6, 2001 | 06:54 AM
vortech305's Avatar
Just ask for a 3 inch universal w/ air tube. U may also wanna find out if your car has dual cats or single.
92' camaro
New 305 block TPI conversion, Flat top pistons,Bore over .30 Forged parts all around,Edelbrock intake,ported plennum,ported corvette alluminum heads, accel cam,52mm throttle bodie, SLP runners Home aid cold air induction, Air foil,ford SVO 19lb injectors,fuel regulator,cloys timing chain, comp alluminum roller rocker arms and pushrods MSD 8.5 mm wires, bosch plattinum plugs, hypertech cap & rotor and coil, Edelbrock TES headers, free flowing catalytic converter and a 3 inch force II flowmaster exhaust system, and a 3 inch cutout,Zoom multi friction clutch, T-5 tranny,billenstien shocks&struts.
Soon to come!!!
Procharger system 12lbs o boost.
New paint job(hawaiin orchid purple)Cast alluminum ZR1 rims w/ 275 tires.
Favorite quote: "where ever u go, there u are"
Other car;
1971 plymouth Duster
Mods:340,edelbrock victor jr. intake, 650 4 barrel holley, heddman headers,40 series dual flowmasters, cold air intake,4:10 gears, just got a new paint job and cragar rims with 315 tires in the back.
:Yeah its not a chevy but damn how many 71' dusters have u seen in the streets.
Old Mar 6, 2001 | 07:11 AM
Ray87Z's Avatar
Car: 94 Z28
Engine: LT1 w/ headers, catback, CAI, tune
Axle/Gears: 3.23s
If you just ask for the replacement cat for your car they'll hook you up w/ the correct cat. It runs $99, I'm running it w/ my TES headers and Hooker cat-back. It is virtually identical to the stock cat in the way you'll set it up.
Apparently there is also a cheaper 3"er, but I'm not sure if it has the bolt on I-pipe setup just like the stock cat or if it's slip fit on that side as well and you have to do some slight custom stuff there. I also don't know if you can reuse the stock cats hanger w/ the cheaper universal cat. Perhaps vortec305 can fill in the blanks here...
Ray87Z
-Vortec headed 350.
86 IROC w/ a cammed 305 TPI.
Formerly Ray86IROC.
www.inter-scape.com/Ray
Old Mar 6, 2001 | 05:39 PM
MilehighBird's Avatar
Car: 1987 Firebird Formula
Engine: 305 LG4
I have the 3in Catco converter(pn #2607),it has air tubes.Got it from summit for like $93.
1987 Firebird Formula LG4,700R4,WS6,2.73 open rear
Current Mods:Flowmaster 3in. American Thunder cat-back,3in. Catco converter,L69 dual snorkel,K&N filter,roof console,Pioneer 1.5din cd player,BostonAccoustics 4x6plates,eclipse 6x9
ComingSoon! 350 crate motor(caprice),SLP coated 1 5/8 headers,edelbrock intake,edelbrock aluminum water pump
Old Mar 7, 2001 | 07:03 AM
im's Avatar
im
One more quick question: If I buy the 3 inch will it bolt up like the stock converter(does the 3 inch have the flange on the one end so you can bolt it up to the cat hanger under the car????....and is the 3incher the same length as stock???or will I have to weld extensions for it to fit???)..I want a direct fit so it will bolt up to the Edelbrock headers and the flowmaster cat back exhaust
Old Mar 7, 2001 | 07:17 AM
im's Avatar
im
<font face="Verdana, Arial" size="2">Originally posted by im:
One more quick question: If I buy the 3 inch will it bolt up like the stock converter(does the 3 inch have the flange on the one end so you can bolt it up to the cat hanger under the car????....and is the 3incher the same length as stock???or will I have to weld extensions for it to fit???)..I want a direct fit so it will bolt up to the Edelbrock headers and the flowmaster cat back exhaust. Also should I get it with or without air tube??? .I have the smog stuff removed. When I take emmissions test will it pass without the air tube and smog pump???
</font>
Old Mar 7, 2001 | 09:24 AM
im's Avatar
im
<font face="Verdana, Arial" size="2">Originally posted by Ray87Z:
</font>
To Ray87Z: can you give me the part number for the direct fit CAT for an 88 irocTPI
to Ray87Z: Can you give me the part number for the direct fit Cat for an 88 iroc 350tpi
Old Mar 7, 2001 | 02:52 PM
Ray87Z's Avatar
Car: 94 Z28
Axle/Gears: 3.23s
Naw, I don't think I still have anything w/ the part number on it. I'll look though.
Ray87Z
-Vortec headed 350.
Formerly Ray86IROC.
loud91rs
Camaros Wanted
Mar 28, 2016 04:13 PM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
bjpotter
Oct 4, 2015 07:48 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
