A.i.r. Tubes And Pump Removal
Old Dec 10, 2002 | 07:04 AM
F-BOMB's Avatar
If I remove the A.I.R. tubes and smog pump but keep a cat. will it pass emissions with headers and clean running motor. Anyone done this and passed?
Old Dec 10, 2002 | 08:59 AM
mess21's Avatar
thats a good question becasue i'm doin a tru dual setup like fastthirdgen did and i'm removing the pump and other junk but plan on trying and throwing on a cat on each side after the muffler durin emissions testin only. but i live in ny and my car has to go on a dyno and run to pass emissions so i don't know
Old Dec 10, 2002 | 09:28 AM
F-BOMB's Avatar
C'MON GUYS, SOMEONE HAS HAD TO TRY AND PASS W/O THIS STUFF. OPINIONS?:lala:
Old Dec 11, 2002 | 05:36 AM
mess21's Avatar
nobody has any input here????
Old Dec 11, 2002 | 01:20 PM
firebirdpl's Avatar
Car: 89 Formula
Engine: 305 TBI
im in long island new york, and passed emmisions with a rotting cat and no air tubes or smog pump. plan on replacing with new cat and full exhaust including headers in the spring, but i wouldnt worry the pump is just one of those things that is there becuase it always has been it is pretty much useless
Old Dec 12, 2002 | 01:07 AM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
I have no AIR tubes.....
but still have the pump hosed to the CAT. Passed with no problems.
Old Dec 12, 2002 | 06:23 AM
F-BOMB's Avatar
Thanks for the input guys. I'm gonna consider removing the air tubes and the air pump, but leaving the cat. By the way, do you guys have a tpi setup with a computer?
Old Dec 12, 2002 | 08:10 AM
PLANT PROTECTION's Avatar
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
A good running motor with only a cat will pass the dyno sniffer even without the AIR system. However, if you have a visual you will prob run into problems. In Indiana, they look under the car for a cat and they didn't say anything about it not being hooked up to the AIR system.
Old Dec 12, 2002 | 08:17 AM
FruityOne's Avatar
Car: 1989 TransAm GTA
Engine: One sweet modified 355 TPI.
Transmission: The kind that shifts....
Yeah, in Roselle IL, they never looked under my hood whenever I went in for emissions. They did however put my car on a dyno for the emissions test.
I think I'll wait till my T/A is due for another E-test and after that I'll remove the A.I.R. and stuff. But I'll leave the cat as I don't mind having it.
Old Dec 15, 2002 | 01:45 PM
kidcamarosc's Avatar
if you just remove the tubes and pump isn't the cat gonna end up clogging because air isn't being injected into it???
Old Dec 15, 2002 | 09:32 PM
holmes677's Avatar
will removing the AIR tubes and pump hurt performance on an 86 tpi?
Old Dec 15, 2002 | 10:33 PM
MelloYello's Avatar
I posted on my emissions experience a few months back. You might be able to find it by doing a search. In a nutshell, on my '90 350 TPI I had 12* initial timing, 50 psi fuel pressure, no air tube to cat or smog pump and still passed with 1/3 of the max emissions (i used a Dynomax 3" superflow cat). As far as clogging, its not a problem because I flanged my cat and an equal length of straight pipe. After I passed, I unbolted the cat and bolted in the straightpipe. Hope this helps.
-Kyle
Old Dec 15, 2002 | 11:40 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
i think it all depends on where you live, what the inspector does when he inspects, and what condition the rest of your stuff is in.
i think though that most of us take that stuff off knowing that we have a buddy or whatever that can give us inspections without caring.
-Brian
Old Dec 16, 2002 | 12:58 AM
Confuzed1's Avatar
Car: 83Z28 HO
I think I can answer a couple of the questions. The CAT won't plug by removal of the AIR tubes. The AIR tubes are only used when the CAT (and engine) are cold. Injecting the air at the exhaust port adds the extra oxygen needed to burn off any excess hydrocarbons during cold operation, like running slightly rich due to choke being on. The system has a control valve for that (AIR management valve).
When the CAT warms with the engine the catalyst start doing thier job, and a vacuum signal is sent from a temperature controlled vacuum tower screwed into your intake to the control valve and then the control valve shifts all air to the CAT...the extra air in the CAT helps it out also, but only after it's warm. Air is cut out to the exhaust AIR tubes altogether. The tubes are only a cold engine emmission requirement!!
So long as you keep the pump, and hose it directly to the CAT - It'll work...it just takes the CAT a little longer to warm up. Don't get your car E-checked when the engine's cold however...
Frozer!!!
Jan 19, 2024 04:55 PM
toronto formula
Nov 10, 2015 06:17 AM
backtothe80s
Sep 5, 2015 12:39 AM
Street Lethal
Aug 13, 2015 08:28 PM
3rdgenparts
Aug 8, 2015 07:09 PM
