Liquid Weld... Does it work?
Old Mar 15, 2001 | 10:42 PM
mostafa3k's Avatar
I've been thinking of buying a cat-back. The other day i was at a hardware store, and in the adhesives section i saw what was basically weld-in-a-tube. Apparently it holds up to 1000* or something of that sort. do you know if i could use this to install my cat-back and cat?
Old Mar 15, 2001 | 11:12 PM
The ODB's Avatar
I'm pretty sure that it will not work for very long on exhaust.
Old Mar 15, 2001 | 11:14 PM
JETHROIROC's Avatar
What's wrong with the clamps the cat-back manufacturer gives you?
1990 IROC 350
Mods: Too busy trying to make it run right to mod it.
Airfoil, Dynomax cat-back, Accel coil, 180 t-stat, Bald Eagle tires,
Hypertech fan switch, Ruger P95DC, hot wife, new oil filter,
thick rubber floormats, towels in the seats.
18.0 @ 85MPH since I'm one big-a$$ MF
"It's better to have and not need than to need and not have."
Old Mar 15, 2001 | 11:44 PM
mostafa3k's Avatar
I've been told that eventually they rattle and come loose, and they become a headache.
Old Mar 16, 2001 | 09:28 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I've never had a problem with a clamp. Just make sure you re-tighten 'em after a few days, and after a few days again. Then, you should be good to go!
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Mar 16, 2001 | 11:41 PM
BigChevy342's Avatar
About that half as$ weld, that stuffs like elmers glue, it's worthless, its sorta like an emergency type thing, i used on my old p/u when a rock hit my transfer case mudding, but anyways..it worked but basicly for the ride home, then the diff. fluid leaked out, so stay away, go with the clamps
86 Iroc 305 tpi
91 Chev p/u, 350, ram-air, 3.73 gears
Terrell351
Jun 13, 2021 01:13 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
Jk_Under
Aug 17, 2015 03:08 PM
Fronzizzle
Aug 17, 2015 02:52 PM
