what size are the hooker cat back tail pipes?
Old Feb 27, 2001 | 12:42 AM
hookin88formula's Avatar
just wondering i would like to order some new tips and i am not sure if its 2 1/4 or 2 1/2. do the hooker tips that u can buy in jegs anybetter then the ones the system comes with?
1988 firebird ws6 formula350tpi msd 6al box blaster 3 coil accel 8.8 race wires hooker shorty headers hooker cat back system pro shift light a pillar gauge pod and water temp and air/fuel ratio gauges autometer oil pressure gauge b&m mega console shifter, march underdrive pullies, tpis airfoil cvr high torque starter (love it)
best 1/4 mile run of 14.44@ 96.53
this run is before the new exhaust system
Old Feb 28, 2001 | 11:58 PM
any1 know?
Old Mar 1, 2001 | 01:16 PM
RED82TA5.7L's Avatar
Car: 96 Formula/82 T/A
Engine: LT1/350 TPI
Transmission: T56/TH350
are you talking about the tips or the pipes that come out of the muffler . the tips are 2 1/2" inlet and duel 3" outlets
the tail pipes that come out of the muffler are 2 1/2"
hope this helps
RED82TA5.7L
1982 Pontiac Trans Am
Cross-Fire Injected 5.7l V8
New TH350 Raptor with a shift-kit, 2600 stall torque converter, Eldebrock TES Headers, 3" Hooker Cat-Back.
Mods: 1.6 Proform Roller Rockers, electric fan, Corvette 5.7L computer chip, K&Ns, MSD 6A Ignition Box, MSD Conductor Spark Plug Wires .
Audio: JVC Kameleon CD deck, Jenson 4x6 front, Eclipes 6x9 rear, 2 10" mTx T4000 powered by a mTx 200watt amp.
Black Powder Coated 1990 16x8 Formula Wheels with 245/50/ZR16 Perelli P7000.
For Pictures go to
http://members.theglobe.com/RED82TA57L/mycar/
A cool Trans Am site with Message Boards http://www.transamgta.com
[This message has been edited by RED82TA5.7L (edited March 01, 2001).]
Old Mar 1, 2001 | 04:03 PM
Dan87IROC-Z's Avatar
Mine are 3".
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End
Current Mods: LT4 Hot Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
7.5" 10 Bolt with 3.42s soon to come!
Old Mar 20, 2001 | 02:13 PM
danzig27's Avatar
Car: 91 Camaro Z28
Transmission: TKO 600
Axle/Gears: 10 bolt 3.23
ok....the two pipes come out of the muffler...and then splits off into those dual tip thing so when you're behind the car you see four "holes". What size are those?
Old Mar 20, 2001 | 05:44 PM
gearrrhead's Avatar
Car: 1990 iroc
Engine: 350 tpi
It is dual 2 1/2 id tailpies. It is on thier website.
Old Mar 20, 2001 | 06:16 PM
Ray87Z's Avatar
Car: 94 Z28
Engine: LT1 w/ headers, catback, CAI, tune
Axle/Gears: 3.23s
The 4 "holes" you're looking at are 3 inchers. It has 2 1/2" pipes coming out of the muffler w/ those quad 3" tips on them.
Ray87Z
-Vortec headed 350.
86 IROC w/ a cammed 305 TPI.
Formerly Ray86IROC.
www.inter-scape.com/Ray
Old Mar 20, 2001 | 07:43 PM
danzig27's Avatar
Car: 91 Camaro Z28
Do they all come like that? With the 3" tips? Cause I like the way they look. I just want to make sure that i get the right kit. Also is the pipe going over the axle 3" also?
Old Mar 21, 2001 | 06:14 PM
danzig27's Avatar
Car: 91 Camaro Z28
ttt
Old Mar 21, 2001 | 06:46 PM
Engine: LT1/350 TPI
yes. it is 3" all the way back from the cat to the muffler then after the muffler its two 2 1/2" tailpipes then the tips are 2 1/2" inlet, duel 3" outlet.
yes. all 3 of the hooker cat-back systems have the 2 1/2" inlet, duel 3" outlet tips
i told you in my last post that those 4 holes are 3"
RED82TA5.7L
For Pictures go to
Vintageracer
Jan 10, 2020 05:33 PM
toronto formula
Nov 10, 2015 06:17 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
knight72
Aug 10, 2015 09:32 PM
drathaar907
Aug 6, 2015 04:20 PM
