SLP Headers and Y-pipe
Old Mar 21, 2001 | 10:20 AM
Beefy89's Avatar
Has anyone experienced rattles or vibrations after installing SLP headers and y-pipe?
We need Perry Mason
Old Mar 21, 2001 | 10:26 AM
Joseph Andres's Avatar
Car: 1991 GTA Convertible
yes, make sure the AIR tubes aren't hitting the fire wall. Mine did. I had them welded to the y-pipe.
1988 GTA 5.7L TPI Auto
355 ci. block,TPIS ZZ-9 Camshaft, SLP Headers, B&M Holeshot 2400 Stall Converter, 3.73 Richmond Gears
"Why ride a stang when birds can fly?"
http://www.geocities.com/thegta
Old Mar 21, 2001 | 10:42 AM
Beefy89's Avatar
I don't have air tubes.
We need Perry Mason
Old Mar 21, 2001 | 10:54 AM
since you don't have air tubes, what did you use to cap off the locations made for them at the cat and the diverter valve? If it's not the air tubes then check to make sure the Cat is not hitting the floorpan. Mine did that too. I just had to readjust the Cat position. Where are your rattles and vibrations coming from exactly? Be more specific.
Old Mar 21, 2001 | 11:06 AM
Beefy89's Avatar
No cat either.It sounds like maybe the y-pipe at the collector,hitting the floorpan.
Old Mar 21, 2001 | 11:07 AM
Beefy89's Avatar
It started on Saturday when I installed a new trans mount.
Old Mar 21, 2001 | 11:24 AM
Get a pry bar under there and see how much clearance there is b/w the floor pan and the collector. Moving things around when putting the trans nmount in will relocate things a bit, especially if the set up is new. Sometimes you can get away with a lot of work my just prying to make some clearance. A big pry bar worked great for me. It use to make noise when I would shift from Park to Reverse or from Neutral to Drive, it would just bang. It's all quiet now.
Old Mar 21, 2001 | 06:33 PM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
Installed my SLP 1 5/8 headers last week and they are rattling. It is barely touching my sub frame connector. Fabricating a piece that will hopefully keep it away from the SFC.
Old Mar 26, 2001 | 09:42 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
I have the SLP 3" and it ratted on the pass side frame rail. I switched to a solid motor mount on the drivers side only and it stopped. Vibration is not much more severe than stock (actually kinda cool what the antenna does at idle)
'88 Camaro RS 2.8L
'88 Formula 350 (Too many mods to list...)
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
redformula88
Oct 14, 2015 06:08 PM
Nervous2
Oct 8, 2015 10:53 PM
TX-SleeperC5
Sep 24, 2015 03:13 PM
alpine247
Sep 16, 2015 05:25 PM
