Another Hooker Catback question
Old Mar 30, 2001 | 04:02 PM
Jono's Avatar
Does the hooker catback have a reducer on the 3 inch pipe? There are several models available which one does not have the reducer and will fit on a 3inch cat?
85IROC
Old Mar 31, 2001 | 02:08 AM
Dan87IROC-Z's Avatar
My friend installed one from Jegs on his 85 Z28 and it had a 3" to 2.5" reducer on it. I think it was the 82-85 305 kit.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
Soon to Come: 7.625" 10 Bolt with 3.42s and Accel TPI Intake Base
Old Mar 31, 2001 | 03:14 PM
Jono's Avatar
Thanks for the info, I wonder if the 86-up does not have the reducer on it, does anyone that has purchased this know?
[This message has been edited by Jono (edited March 31, 2001).]
Old Mar 31, 2001 | 05:42 PM
I got the one thats for the 86+ HO models, and it does NOT have the reducer on it, it's 3" all the way from cat to muffler.
L98 TPI 350 (5.7L)
Old Apr 1, 2001 | 09:10 PM
Jono's Avatar
Thank you for all your help
Old Apr 1, 2001 | 10:35 PM
Ray87Z's Avatar
Car: 94 Z28
Engine: LT1 w/ headers, catback, CAI, tune
Axle/Gears: 3.23s
You want the one listed for 86-92 single cat 5.0/5.7 TPI cars. That model is 3" w/ no reducer. Have it on my 87Z, bolted up to the stock 3" cat and to the Catoco high flow 3 incher that I put on. 85s originally had some kind of different cat hookup though (maybe it was only on the y-pipe end, I don't know), I assume you aren't running the stock cat setup or something...
Ray87Z
-Vortec headed 350.
86 IROC w/ a cammed 305 TPI.
Formerly Ray86IROC.
www.inter-scape.com/Ray
[This message has been edited by Ray87Z (edited April 01, 2001).]
Old Apr 2, 2001 | 07:54 AM
Aaron87SC's Avatar
I got the proper model for my LG4 and it did have the reducer on it as it was supposed to. They basically have what you need whatever your application is. A word of caution: Although the hangers line up with the stock hangers, they aren't necessarily the same. I had to improvise to get the Hooker hanger to work with the car. Not difficult, but don't get cuaght with your pants down.
1987 Camaro Sport Coupe LG4
700R4 with 2.73 open rear
Hypertech chip, 180* stat
Dual snorkel air cleaner with K&N air filter
CK rods with B hanger
Hooker catback
Old Apr 2, 2001 | 08:45 PM
mcconahay37's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Ray87Z:
</font>
How does that hook up to the cat? Is it a slip fit or some other method? I'm also looking at the Hooker catback and plan on using no cat, so a slip fit adaptor will work best for me.
82 Camaro:
350, Erson cam, ported heads, Crane Hi-6 ignition, Accel supercoil, Comp Cams 1.6:1 rocker arms, Turbo 350 tranny with 2500 stall.
billybob6110
Sep 24, 2016 09:50 AM
formula_novice
Sep 5, 2015 03:58 AM
tricky1
Aug 23, 2015 01:17 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
