About to install true dual exhaust. Any Tips?
Old Apr 5, 2001 | 10:48 AM
Big454blockchevy's Avatar
Car: 86 z28
Engine: Hyd. roller 498
Axle/Gears: 12 bolt 3.90 gears
This shop is going to do it all for a real good price. I went with Hooker headers, flowmasters and 2.5 pipes. I will leave the option of installing converters on both pipes if I need to so I can pass the visual inspection.
Big 454 72 Chevy Nova
383 86 Camaro Z28
10.5:1compression 186 casting Heads,234dur.488lift exh&int,Edelbrock performer intake, Holley750 vac.sec 400 crank,flat top pistons,edelbrock valve springs and lifters,tranny shift kit,kickdown kit and tranny oil cooler. Will install 3.73's later on and might go with a more aggresive cam.
[This message has been edited by Big454blockchevy (edited April 05, 2001).]
Old Apr 5, 2001 | 02:18 PM
SUPER-SPORT-CHEVY's Avatar
Well if a muffler shop is doing it for you than no help is nessasary I have duals on my 85 "350" and i noticed a big power increase.
"Post your results after the swap."
GL SSC~!
Old Apr 5, 2001 | 06:07 PM
Car: 86 z28
Although I am not doing the work myself I just wanted to see what you all tought of this exhaust package. I will post results .
383 86 Camaro Z28
Old Apr 5, 2001 | 11:26 PM
DARCOM's Avatar
Car: 84z28
Engine: chevy 388
i have duel exhaust i started from the mufflers
and worked my way to the collectors
the hardest part for me was over the rear
axel and the tranny cross member.
check out my simple page at:
http://darcom.home.texas.net/
388 SuperRam, DFI, Vortech R trim ,N.O.S.,alki injection,
Dart sportmansII heads,50 pound injectors, Headman full headers
duel 3' exhaust,and Flowmasters, Ford nine inch with 370's
Ronal rims with Nitto drad raidals.
Old Apr 6, 2001 | 01:55 AM
Car: 86 z28
Thanks Darcom . I copied your exhuast layout . I might go with that routing but instead go with the tips like your traditional Z28. NOt that there is anything wrong with the way you have em.
383 86 Camaro Z28
Old Apr 6, 2001 | 09:34 AM
Snomadnes's Avatar
Darcom how much were the full length headers?
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
beastin91rs
Oct 9, 2015 07:38 AM
Dialed_In
Aug 20, 2015 01:45 PM
