Go 3 inch, or 2 1/2?
Old Dec 30, 2002 | 11:32 PM
dunerida82's Avatar
Car: 1991 RS
Engine: 305 TBI
I know a lot of third gens run full 3 inch, and a lot do 2 1/2. I was wondering if there is a performance deficiency if you use either or. Thanks for the time.
Old Dec 31, 2002 | 12:31 AM
xaivior's Avatar
Car: Camaro
Engine: 355
Transmission: th-350
Axle/Gears: 3.73 welded
I been researching this topic alot lately i'm about to run my exhaust ..I found that it all depends on your setup and if your planning on running true duals or single. i'll be going with 2.5" so I dont loose velocity
Old Dec 31, 2002 | 12:35 AM
LastViceRS's Avatar
Car: '91 RS
Engine: LO3, For now...
I figure 2-1/2" is good, but 3" is better, assuming we're talking about 305 or bigger. I figure the better it flows, the better it goes. Just my 2c.
Old Dec 31, 2002 | 03:04 AM
MdFormula350's Avatar
you might as well go 3 inch...
Old Dec 31, 2002 | 05:44 AM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
Re: Go 3 inch, or 2 1/2?
What engine you got??
Old Dec 31, 2002 | 05:51 AM
DABE's Avatar
3 inch is awesome...im haveing my 3" SLP catback and 3" catco cat welded up today...i need the 3"....im running 450hp at the fly...
Old Dec 31, 2002 | 10:55 AM
AFatHippo's Avatar
Car: '88 Camaro
Engine: 355
it really depends what kind of setup you got. if you dont have a lot of performance mods and youre using a muffler bent y-pipe into a stock cat, i doubt there would be much of a difference at all. but, a 3" wouldnt hurt and you could use over in the future if you upgraded your car.
Old Dec 31, 2002 | 02:50 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
IF you wanna stick with single exhaust get 3'' unless you're pushin over like 450hp.
Old Dec 31, 2002 | 05:47 PM
Parrydise7's Avatar
My LG4 was originally equipped with a 2.25 inch (I think) "Y" pipe. I replaced it with a 3" Y from an IROC. I gained all of nine horses (but keep in mind that 305 is bone stock except for a dual snorkel and an Edelbrock cat back exhaust). GM sells a dual-cat exhaust that is 2.5." That dual cat exhaust came with the HO 350 package. Take your pick.
Old Jan 1, 2003 | 11:23 PM
dunerida82's Avatar
Car: 1991 RS
Engine: 305 TBI
I've heard the same. Good call, I think I'll make my decision on that note. Thanks fellas.
Old Jan 2, 2003 | 04:36 AM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
This is a non-issue if you want to make any kind of decent power. Go 3" or go home ...
Old Jan 3, 2003 | 04:29 AM
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
Transmission: ZF 6 speed
Axle/Gears: Dana 44 3,33
The 3 inc one makes a much better noise too.
Old Jan 3, 2003 | 11:20 AM
Parrydise7's Avatar
Okay, I may have not made it clear in my prior post so I'm adding this. That dual cat exhaust from Chevy is 2.5", but there are two tubes, so it is 2 times 2.5 inches. BTW, that dual cat exhaust may have been standard equipment on the 1LE. So, you have a choice between one 3" pipe or 2 2.5" pipes.
Old Jan 4, 2003 | 11:10 PM
LastViceRS's Avatar
Car: '91 RS
I may have oversimplified the issue in that post, wasn't really considering duals. But I'm sticking with the general statement.
Old Jan 5, 2003 | 09:57 AM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
I would go with 3" exhaust if you are looking to get every bit of power.
Even with the dual cat system it is not 2.5 x two pipes. It is only 2 pipes till they rejoin after the cat. The rest of the exhaust is one pipe from the intermediate pipe back to the muffler.
It is based on the bottle neck principle. The smallest restriction that you have is the maximum that the flow will be. Based on bernouli 's principle the reduction at the smaller section will increase speed but the volume will be reduced. Then when the flow hits the muffler and splits back to 2 pipes the velosity will decrease again, but the volume will not be able to go back to its original amount because of the reduction due to boundry friction that occured during the trip down the intermediate pipe.
This is why gm went with a 2.5 inch pipe after the cats in the HO unit not 2.25. However, they did not go for 3 because the engine power loss was not siginificant enough to justify the increase noise that would be a result of 3" pipe that they would have to try to tame and not cause more restriction.
If you have a stocker 305 2.5" will be plenty. Even if you have headers and a 2.5 good flow cat 2.5" will be fine. However if you mave some power in a 305 or a 350 3" cat back system, headers, and a 3"cat.
Thats my 2 cents.
Old Jan 5, 2003 | 01:26 PM
DTL504's Avatar
Car: 84 Z28 Convertible 2 Seater
Engine: Dart Little-M SBC 400
Transmission: Pro-built Automatics 700R4
Axle/Gears: Strange Engineering 3:73
Just remember that BIGGER is not always BETTER. You must design your Exhaust to compliment your engine combination.
By going bigger yo give up low end Torque and gain horsepower up top. With the smaller Pipes would improve Low end reponse but loose up top. Basicallly it all depend on what you are doing with your engine. If you dont spin your engine above 6000 RPM you would see minimal gain by using the larger pipes...
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
gord327
Sep 29, 2015 10:18 PM
