I have had it know one can tell me what gaskets ports I need not even edelbrock
Old Apr 21, 2001 | 06:20 PM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
Please help, I want to order earls header gaskets, but know ones seems to be able to help, my choices are 1.50 by 1.50 and 1.36 by 1.36, I have 1 5/8 headers on a gm replacment 350, 1.50 is still smaller then 1 5/8 so Why do some people say they are to big? earls can't help, gm can't help, and I can't measure them because it has to done the same day. thanks
86Z28, GM 350, Jet perf Q-jet & chip Dual snorkel air cleaner, Edelbrock performer intake, Edelbrock headers, Edelbrock cat-back, Off road pipe, MSD 6AL, Accel Super Coil, Taylor Spiro-pro wires, Rapid fire plugs, Jet fan switch, World class t-5, Hurst Short Throw Shifter, Ram Flywheel, Center force dual friction clutch,Aluminum drive shaft, BW disc rear 3.45's & a posi, PBR calipers, Earls braided brake lines, Polygrapite bushings all the way around, poly tranny mount & torque arm mount, Hotchkis lower control arms & panhard rod, Rancho limiter straps, KYB struts & shocks, Gm Wonderbar, Edelbrock strut tower brace, SSM sub frame connectors, Jamex lowering springs, Carbon metallic brake pads, Crossed drilled rotors, Mobil 1 Tranny fluid & motor oil, GM syntheic rear end oil, K&N, Grant stering wheel, 1,200 watt system, Jet Black Paint, 91 Z28 rims, 92 wing, Tinted windows.
Old Apr 21, 2001 | 06:52 PM
Tas's Avatar
Tas
the gaskets that came with my 1-5/8" hooker headers are 1-5/8" square. I just measured them. I'm gonna be getting better verisions of them though. Cardboard tends to blow out after a bit.
-Tas
'89 Formula WS-6
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
Soon to be installed:
Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248), Catco 3" cat, and injector spacer.
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
AOL IM: superGRtaz
Old Apr 22, 2001 | 10:10 AM
BLACK Z's Avatar
Car: 86 Z28
Thanks man so the inside diameter is 1 5/8 square? that is not the outside right? thanks alot
sreZ28
Oct 22, 2015 08:21 AM
mrestrictrplate
Sep 21, 2015 11:24 AM
Rally Smith
Sep 14, 2015 06:59 PM
toronto formula
Sep 10, 2015 07:31 AM
hdis2002
Sep 8, 2015 02:52 PM
