edelbrock exhaust question
Car: 1984 Trans Am H.O.
Transmission: 700-R4
Axle/Gears: stock 3.73
I have a stock 84 trans am with L69 engine. The stock exhaust system has holes all over the dammm thing. I am planning on getting edelbrock tes headers, catco cat, and the edelbrock cat-back system. Besides sounding better, how much more power do you think I will get with this setup? should i get the headers coated even though i live in Arizona?
Car: 1987 IROC Z28
Engine: 6.0L LQ9 crate engine
Transmission: Performa Built 700R4
Axle/Gears: 3.42 10 bolt, Eaton/Moser
Well, I too live in sunny AZ. I have a set of Edelbrock headers on my '89 IROC and a set of Hookers SC/LT on my '87 IROC. Here in AZ it's so dry and dusty that the headers and exhaust systems don't rot away like in other areas of the US and Canada. Mine are not coated, just hi-temp painted. Coating them will preserve them and give a nice look to them as well as cut down some of the heat dissipated from them.
If you have the extra $$ you can get Edelbrock headers now in a nice nickel coating direct from Edlebrock. Check out their website at:
www.edelbrock.com
SLP makes some good stainless headers as well.
These shorty-type headers may add a few extra ponies, but not a whole lot. I'd say about 15 hp. Maybe a little bit of low end torque too. What they really do is add a nice exhaust note and rumble to the car throughout the rpm range.
Great mod, go for it!!
Phil87IROC
Blue '87 IROC, 383 Crate Motor, KB pistons, AFR 190 heads, ZZ-9 cam, Edelbrock RPM intake, Hooker SC/LT headers, Edelbrock 750 cfm Carb (#1411), stock T-5, GM 3.42 rear w/Auburn posi.
Ohio Valley Dragstrip Trophy Bracket WINNER - 8.39 ET on a 1.82 sec. - 60'. Best MPH = 84.44. Still Tuning Carb!
Red '89 IROC L98, 700R4, T-Tops, K&Ns w/open air boxes, 160 T-stat, Hyper Chip, gutted MAF, 53kv coil, MSD wires.
www.edelbrock.com
Phil87IROC
