removing cat
removing cat
I want to remove my cat from my car and replace it with a straight pipe. I have done some research on this, so please don't tell me to do a search. I have a couple of questions though:
1. Do I have a O2 sensor on my cat? I have a 92 RS 5.0L TBI.
2. Second question is that i have heard a lot about the code 32. Will i get this? If so what can i do to fix it?
3. Is there any reason, besides emissions, that i should not remove the cat?
-Kevin
-Kevin
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
Re: removing cat
-Kevin
-Kevin
Car: 1988 Mustang GT
Engine: 302
Re: removing cat
-Kevin
-Kevin
2. who cares pull out the stupid check engine bulb
3. no
hope this helps
Originally posted by brent4a
I LIVE IN MD , AND YOU WILL NOT PASS EMISSIONS WITH OUT ONE. THEY DO CHECK TO SEE IF YOU HAVE THEM ON.
Also, I do have a 02 sensor. However, I decided to just switch the cat to a high-flow after reading the sticky about this.
Thanks for all of the help
Car: 90 Formula
Engine: 305 tpi
MD
FOR YOUR INFO , IT CAN BE CALLED TO TAKE THE TEST EVERY 2 YEARS........DEPENDS ON HOW OLD YOUR CAR IS. AFTER A CERTAIN AGE , ITS EVERY 2 YEARS PERIOD..
Re: MD
by the way, why are you always yelling in all of your posts???
Car: 90 Formula
Engine: 305 tpi
Sorry.......was at work and forgot to take the caps lock off..You are correct.....i forgot that in the more rural areas they still dont test. Where i live it started 5yrs ago. It really sucks here
