3 Inch Cut-Out
Old May 17, 2001 | 02:04 AM
'91 Speed Demon's Avatar
3 Inch Cut-Out
I have a 3 inch single exhaust pipe and flowmaster. I was wanting to know if there is enough room at the exhaust splitting point under the passenger side door to be able to put in a 3 inch cut-out. One muffler shop I talked to said they wouldn't do it for me because there was not enough room for the extra pipe to exit out the side of the car. "The pipe would pretty much just be dragging the ground."
Does anyone have any experience with this type of thing? Any suggestions?
I am new at working on cars, so please bear with me.
'91 Z28 Coupe 350
Flowmaster, K&N
Old May 17, 2001 | 04:25 AM
Tas's Avatar
Tas
put the cutout after the rear axle and add another 3" tailpipe. that way it will look like dual 3". You can even have different plates made between the tailpipe and the cutout just like the Borla adjustable system
-Tas
'89 Formula WS-6
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
Soon to be installed:
Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248), Catco 3" cat, and injector spacer.
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
AOL IM: superGRtaz
Old May 17, 2001 | 10:47 PM
I already have dual 3 inch tips exiting out the back. Do you know of any way to have the exhaust exit before the back tire?
The way my exhaust is setup, It is only 2 1/2 inch until it hits that breaking point under the door, then it widens into 3 inch.
Would it be possible to have a 2 1/2 inch cutout before it widens into the 3 inch? Maybe then the muffler shop would be able to maneuver the smaller pipe to exit before the rear tire.
Any possibilities of that working out?
Thanks for the help.
'91 Z28 Coupe 350
Flowmaster, K&N
Old May 18, 2001 | 01:04 AM
Tas's Avatar
Tas
sounds like you should just get headers.
Old May 18, 2001 | 08:10 PM
dtpmike's Avatar
I had a muffler shop put in a summit cutout. They trimed the ends of the cutout off and then cut the pipe and put it in. IT is kinda close to the groudn, but i think i have only scrapped it once. Also they only charged me $25
Old May 18, 2001 | 10:41 PM
NTChrist's Avatar
Yeah, dtpmike's right. I have the flowmaster single 3", and the summit cut-out. I made the mistake of not painting/coating it. Rust! But, no problem with the exhaust shop.
Obviously, the exhaust shop is going to have to do some cutting to fit the cut-out before your exhaust splits.
No guts, no glory.
Old Mar 4, 2007 | 08:43 PM
roadking555's Avatar
exhaust cutout
I have a 1987 GTA, 3" exhaust pipe and was going to put one of those new electric cut outs. Has any body tried that? will it hit the ground?
Old Mar 4, 2007 | 09:25 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
I`m not sure but I`d like to know how well they work and if tou get noticeable gains out of it.I was thinking about getting one myself.
Old Mar 4, 2007 | 11:44 PM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
i had mine put in about a foot in front of the rear axle there is a open spot.
Old Mar 5, 2007 | 08:16 PM
electric cut out
So it's after the cat, I was thinking of having mine before the cat. but my clearance is better closer to the real wheels. I don't have my car here, it's in winter storage.
Old Mar 5, 2007 | 10:40 PM
1991camcamaro's Avatar
Car: Camaro RS/Z-28 clone
Engine: 305 TBI LT1 cam
Transmission: MM 700R4
Axle/Gears: 3.23 Posi w/LS1 brakes
passenger side cutout before the tire
is this what you are looking for?
Old Mar 5, 2007 | 10:45 PM
heres another on ground level
heres one more at the ground level, i havnt hit ground back here yet.
I DO AVOID Speed bumps at all cost due to my low hanging y pipe
Old Mar 5, 2007 | 11:12 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
what kinda gain do you get from the cutout?
Old Mar 5, 2007 | 11:38 PM
ok i am not a exhaust expert, so i am just telling you "my" story
ok i believe it all depends on the total exhaust system from start to finish.
when i dyno-ed her she gain about 35 torque at the rear tires.
and only a whooping 5 hp when opened, but thats mostly middle to upper range rpm levels like full drag cars at the track, open headers.
placement of the cutout is important too.
actually down low when i have it open she kind on dogs, not enough backpressure.
but i mostly us the cutout for SOUND!!! its so much louder
Old Feb 3, 2013 | 11:54 PM
BCiroc's Avatar
Car: 88' sport coupe iroc
Engine: 305 tbi
Axle/Gears: 3.42 gears with a posi
Re: 3 Inch Cut-Out
if im still running the original 305 with 9.3:1 compression ratio, will putting a cut-out in increase my power or would it be a waste of my time and money?
Old Feb 4, 2013 | 08:07 AM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
Re: 3 Inch Cut-Out
It would lose a lot of low end power
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
gord327
Sep 29, 2015 10:18 PM
