Life Span W/O coating
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Can anyone tell me the "lifespan" of headers without having them coated? I know everyone that doesn't coat says they wished they did, and that most say that they will have them coated (or buy them already coated), and I understand the reasoning - to reduce under-hood temps and prevent rusting.
BUT - it also seems that the coating ends up costing almost as much as the headers themselves (Hooker 2055's $349 + Jet Coat $290).
Also, how much success (lifesapn) is there with removing factory paint and either:
a) repainting with hi-temp paint
b) coating with this Cermakrome stuff
I mean, if I do nothing, and they last 4 years, I'll save the $$ now. Or, if I can spend an extra $50 or less on hi-temp paint, or this Cermakrome and be relatively assured of 4 yr. lifespan, maybe I'll try that.
Please give a budget-minded newbie the scoop.
If you don't have to drive in snow, which means salt on the road, I wouldn't sweat it.
The headers on my IROC were bead blasted and I sprayed 'em with VHT and they are still fine after several months of DAILY driving.
I had uncoated headers on my 67 Chevelle for 5 years and NEVER had a problem.
I've had at least 10 vehicles with headers, and all but one or two were uncoated. I've NEVER had a header need to be replaced because of rust.
What do you think people did of all those years BEFORE coating became available??
HTH
HTH
Car: 1989 C4
Axle/Gears: 307
The wisher's complaint isnt really rust its the fact the cheap paint peels off and scratches easy. The coating just makes it look better longer. Theres people with 60's cars that still have the same headders on there since they put them on 30+ years ago and they havent rusted off yet.
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
HTH
HTH
i agree
Car: 2007 Corvette Z06
Engine: LS7
Transmission: 6 speed
I have about 2 1/2 yrs ~30-40K miles and some driving in the snow(a few times only) on my high temp painted edelbrocks, sure the paint has come off on the bottom side of the y-pipe and is peeling/chipping off everywhere else, but I doubt they are more than 5% worn due to rust. They do see salt living 5 miles from the beach and I just switched them from one car to another so I saw them up close. The next headers I get will probably be coated though, b/c painted = ugly; also I've burned more than enough wires(could probably be avoided with better routing) and the cost of coated headers vs. the supercharger make the $300 not a big deal.
Car: 1991 Camaro Z28
David
