Any recommendation on getting off 11 year old bolts?
Old Jun 12, 2001 | 10:41 AM
Steve00YZF's Avatar
I'm going to be gutting my cat this weekend, but the bolts on there are like 12 years old. The head immediately stripped, and the threads literally fell off when touched with a screwdriver. I have tried a few penetrants, and am about to just saw the bolts, but I would rather not if possible.
Old Jun 12, 2001 | 11:14 AM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
You might want to apply a little bit of heat to it. Either run the car for a minute or use a torch to heat everything. This may work, it may not but it's worth a try.
Good Luck!
Old Jun 12, 2001 | 03:21 PM
TransAm383's Avatar
11 years is nothing. I helped a buddy of mine yank the motor from a 140000 mile Chevelle last month-you would not believe how rusted every bolt on that car was. Anyway, you'll definitely need to heat them and use a penetrating oil. What we did was use an oxy-acetelene torch to heat the bolts red hot, then we sprayed Liquid Wrench on the bolts and put the wrenchs to them. It took 2 to 3 cycles of this to break the bolts loose, especially the ones exposed to high heat, like on the exhaust. Hope this helps.
Old Jun 12, 2001 | 06:30 PM
91B4C jacob's Avatar
You might want to try some stuff Called PB BLASTER I have see(Its the only pen. oil I use) this stuff work magic IT IS THE BEST it is kinda hard to find though (at least around here) and use heat but like I said PB Blaster there is nothing beter
Ya sure it is just an RS
B4Cyaa
1991 RS B4C
Former Nebraska Highway Patrol Car
305 TPI
WC T-5
Four Wheel Disk Brakes
Only Options
Rear Defrost
Am-Fm Radio
Red-int White-exe
One BA Of A 350 In The Works
Mods
Dynomax Cat Back (to hold me over till I got the $$$ for the Borla)
best 1/4mile Run of 14.92@94.83
with 145,000 on her
https://www.thirdgen.org/rides/index.tgo?action=view&rideid=2201
god speed dale
Old Jun 13, 2001 | 05:53 AM
Mista's Avatar
Car: 1986 Trans Am
Engine: 305 TPI peanut cam
The key to using PB Blaster is to let it soak in for 20-30 minutes. I got mine at local Meijers Superstore.
86 T/A 5.0 A4 & 2.77 gear
15.62 @ 86 mph
93 Civic 1.6L
13.5 @ 100 mph
hectre13
Dec 11, 2023 08:14 AM
LT1Formula
20
Nov 14, 2015 12:02 AM
Reddeath210
Oct 6, 2015 08:20 AM
Dialed_In
Aug 20, 2015 01:45 PM
