Removing Pass. side eshaust manifold..
Old Jun 25, 2001 | 10:03 PM
92fire-audio's Avatar
I've got the drivers side manifold off, the Y pipe off, and the cat off. I'll be getting my headers in on thursday so I'm not in a hurry. It looks really cluttered on the pass. side. Does anyone have any tips for getting the last 3 bolts off of the exhaust manifold??
Thanks!
Old Jun 26, 2001 | 12:12 AM
chrisandkristin's Avatar
hey i just got my pass side header on i found that the best way is to get under the car and do it that way....u might want to take off the starter to gain more access...hope this helps
Old Jun 26, 2001 | 12:37 AM
Does the starter just bolt in and out, or do I have to do anything else to it? I don't have any expertise with shimming or anything like that, so if it doesn't just bolt in and unplug then I should probably just try it with the starter on. Thanks for the advice.
Old Jun 26, 2001 | 08:11 AM
custman87T/A's Avatar
With the SLPs I just put all bolts in from the top, a couple of scraped knuckes and some cursing and it all worked out fine.
Old Jun 26, 2001 | 09:11 AM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
I agree with custman87T/A. It been 2 weeks since I finished mine and I still have battle scars. You think it was fun getting those manifolds out just wait til you try and cram those new headers down that hole. Removing the starter may be your best option and try putting the passenger side header in from the bottom. Next time I will just yank the @%$# motor.
91 Camaro RS 5.0L Black Convertible 700R4
** Added so far **
*GM Wonderbar
*Alston SFC's
*Turbo City Inj Spacer
*Dual Snorkel Air Filter
*March Performance Pulleys
*GM 3.42 Gears with OEM Zexel
*Edelbrock headers
*3" High Flow Cat
*3" Dynomax Exhaust
*Walbro 255 lph Fuel Pump
Old Jun 26, 2001 | 11:03 AM
Well I just can't seem to get the very last bolt off.. I can't get a ratchet on it, or a closed end wrench.. I'm trying from underneath and above but I can't get anything on it..
Also, I got the nuts off of all of them but on a couple, the bolt is not coming out, whats the best way to get the entire bolt out, or should I just wait till i get the whole manifold out?
Thanks!
Old Jun 26, 2001 | 12:43 PM
Nevermind, I got it off eventually. I had to go in at a wierd angle (almost parallel to the manifold) from under the car and use a closed end wrench.
Thanks to all who replied.. I can't wait to install the new headers on thursday, heh, not.
Old Jun 26, 2001 | 05:42 PM
For those hard to reach or turn bolts I used a torch and bent a 3/8 box wrench into a 90 deg. angle and it fits and works fine
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
Street Lethal
Aug 14, 2015 08:25 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
3rdgenparts
Aug 8, 2015 07:09 PM
3rdgenparts
Aug 5, 2015 11:57 PM
