why am I cursed to be an idiot please help
Old Jan 26, 2003 | 05:40 PM
westman's Avatar
Car: 90 Camaro RS
Engine: 6.3L 383 V8
It never seems to fail. The smaller the project, the more of an ordeal it becomes. I installed some flowtech headers on my 90' RS. I had to take out the oil dipstick and for the life of me I cannot get it back in to read properly. I changed to oil to exact specs so I know the tank is full. Still no reading though. How far in is it supposed to go? Shouldn't it somewhat slide in? Please help a dumbass in need
Old Jan 26, 2003 | 07:40 PM
MdFormula350's Avatar
keep trying to get it in, wiggle it in or something....
never had mine out so i dont really know for sure, sorry.
Old Jan 26, 2003 | 09:25 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
i took the dipstick out of my 305 and slid it back in easily. when i installed a dipstick into my 355 i had to hammer it in, and i dont even want to think about having to remove it.....
Old Jan 27, 2003 | 02:57 AM
westman's Avatar
Car: 90 Camaro RS
Engine: 6.3L 383 V8
damn thats not what I wanted to hear brody. This sucks. Well I guess I know what I'll be doing on my days off Thanks for the help guys.
Old Jan 27, 2003 | 01:46 PM
383 rocket bird's Avatar
Look from underneath and see if the tube that houses the dipstick itself is pulled out from the block. There should be a shoulder on that tube that will be pressed up against the block when it is fully pressed in. If this tube is not in all the way then your dipstick will be in the tube all the way but you will not get a reading on the dipstick. If the dipstick tube is not in the block all the way, get a pair of pliers and put them around the dipstick just above that shoulder.(vice grips work well) Try to hit the pliers with a hammer while someone pushes down on the top of the dipstick with a block of wood or something. Conversly you could pull down on the dipstick while someone else taps on the top of the dipstick with a block of wood and a hammer. Be very careful not to damage the dipstick tube. Hope this helps. -John
mfp189
Sep 27, 2015 09:25 AM
TOMcat GTA
Sep 15, 2015 09:31 AM
Rally Smith
Sep 14, 2015 06:59 PM
ccop
Convertibles
Sep 14, 2015 04:13 PM
FormulasOnly
Sep 6, 2015 10:42 AM
