What's that metal pipe on my new cat for?
Old Aug 3, 2001 | 07:22 AM
KeithO's Avatar
I just got a new 3" Random Tech cat for my IROC this week.
I know nothing about cats, so I have some dumb questions:
What is the metal piping on the body of the cat supposed to he hooked up to? What is the purpose of it? Is it necessary to be able to pass emmissions tests?
The existing cat also has this metal pipe, but it about 2 inches long and has been crimped shut by a previous owner.
Old Aug 3, 2001 | 07:26 AM
WideOpenVTwin's Avatar
Car: 1992 Camaro RS
Engine: 355
Axle/Gears: 3.73:1
It's for connecting to the smog pump. I don't think your camaro has a smog pump that connects to the converter (or one at all). Just close it off if that is the case. The purpose is to heat up the converter when it is cold so it can start reducing emissions quickly. It also supplies O2 to help burn unburned gasses
Old Aug 3, 2001 | 08:04 AM
KeithO's Avatar
OK, thanks. Sounds like I should just crimp it and forget about it.
Old Aug 4, 2001 | 12:00 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
All thirdgens have that tube, it goes from the air pump (smog pump) to the cat, and yes its necessary to pass the smog check. If they check for a cat and see its not hooked up they'll probably fail you.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
LC2 TECH
South West Region
50
Jun 30, 2016 10:47 PM
PurelyPMD
May 5, 2016 04:57 PM
mud runner
Nov 2, 2015 07:30 PM
Camaro_383
Sep 11, 2015 11:28 PM
Stroopwafel
Sep 11, 2015 06:38 AM
