Will Flowmaster 40 Series dual out muffler fit F-body???
Old Jul 28, 2001 | 11:44 AM
Flash84Z28's Avatar
Car: '03 S-10/ '87 Trans Am
Engine: mild 350
Transmission: TH350
I have an '84 Camaro Z28 with stock pipes and single Cat. (which is going to be hollowed). I was wondering if the 40 series muffler made by Flowmaster that has one 2.25" in and two 3" outs will fit my car.
Matt
1984 Camaro Z28
-'78 350 with Edelbrock 650 Carb, Edelbrock Preformer RPM Air gap intake, ACCEL plugs & wires, 14" K&N filter.
-TH350 with Hurst Pro-matic shifter & B&M Street shift kit.
-Audiobahn single 12" Sub powered by Sony Xplode amp, Farenheit 6x9" & 4x6" speakers, with a Sony Xplode headunit.
Old Jul 28, 2001 | 05:15 PM
tacoboy's Avatar
Ummm, are you thinking of the 80 series, which is designed to be mounted transversly, or I guess you could be talking about the 40, but in that case wouldn't it be a 3"in and 2.5" outs...anyway, if its the 80 series yes it will fit, if its the 40 series i will say that you can probably have a muffler shop MAKE it fit somehow for a price. Sorry if that doesnt really answer your question.
Old Jul 29, 2001 | 04:25 PM
Flash84Z28's Avatar
Engine: mild 350
Transmission: TH350
Yes, I know that Flowmaster makes an 80 Series replacement muffler, but there is also a 40 Series with a 5"x12"x14" case and three chambers. It is Jegs Part #389-9530462. Does anyone know if this will work?
Matt
1984 Camaro Z28
Old Jul 30, 2001 | 11:40 PM
HrdRockA4305's Avatar
Thats probably 2 outlets on the same side, because the ONLY crossflow flowmaster is the 80.
88 Camaro (not an RS, or an IROC, justa camaro.)
305TBI/700R4/2.73
14" Open Element and Flowmaster 80 seires
Next up: headers and gears
Old Jul 31, 2001 | 04:54 AM
Tas's Avatar
Tas
40 series are called 2 chamber mufflers, 50 series are 3 chambered mufflers. You can get a 40 or 50 series with a 3" in dual 2.5" out, but the 3" in will be on one side, and the dual 2.5" out will be on the other side. The 80 series is 2.5" in that necks up to a 3" inlet. if you want to use it as a 3" muffler, you need to cut the front of the neck off. It is dual opposite 2.5" outlets. there is even a little neckdown add on piece that comes with it makes it easier to weld it to a 2.25" pipe
-Tas
'89 Formula WS-6
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
To be installed eventually far far far into the future: Yours if the price is right and I don't have to ship :
Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248), Catco 3" cat, and injector spacer.
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
AOL IM: superGRtaz
Old Jul 31, 2001 | 10:29 PM
Flash84Z28's Avatar
Engine: mild 350
Transmission: TH350
Okay the 40 Series sounds a little hard to install if I want tips in the stock location, so how much of a differance is there between the 40 and 80 series mufflers sound? Would you go the extra effort to make the 40 fit?
Thanks,
Matt
Matt
1984 Camaro Z28
Old Aug 4, 2001 | 10:46 AM
HT 1985 IROC-Z's Avatar
I think the muffler you are refering to is made for Chevy trucks and others. It is a 40 series muffler with a 3" inlet and dual 2.5" outlets and sounds pretty good....little louder than the 80 series for our cars. Not a true replacement though as both tailpipes would have to exit out the driver's side of the car...kinda like SLP cat-back system. I have heard this muffler on 3rd gens before and I do believe it is considerably louder than my 80 series with no cat and headers. If you are looking for sound and not worried about the stock pipe location, go with it, if you want stock looking, go with the 80 series.
1985 Iroc-Z, 5.0 liter H.O. Black cloth interior, Hard Top!! [ no LEAKING T-tops...YES!!! ]Upgrades: Edelbrock Performer Rpm Intake, Holley 650cfm Zinc-plated carb, Flowmaster exhaust,Accel 8.5 spiral core wires, 700-R4 w/shift kit [ I think it is broken...NO!!!! ], 3.08 rear[ can you say slow!! ]
Soon to have:
A paint job!!! White w/ black sripes, Headers and y-pipe and 3" I-pipe, World-Class 5-speed swap, 3.42 gears, Lots More!!!!! If the funds are available!!
Old Aug 5, 2001 | 01:45 PM
NHcamaro's Avatar
thats not a crossflow its not going to work on your car ...I got that same one on my truck sure wish it would fit on my car
1988 Sport Coupe 305 TBI
K&N
Flowmaster exhaust
Daily driver:
1988 K1500 5.7 4x4 shortbed flowmaster cat-back gutted cat.
AOL: RyanNH84
Old Aug 5, 2001 | 01:48 PM
NHcamaro's Avatar
BTW the 40 makes an awesome sound...you could fit a 40 with single in single out but youd only have one tail pipe
Old Aug 5, 2001 | 01:51 PM
tacoboy's Avatar
also if you look at the specs on flowmasters site, they DO make a true 3" in 80 series...just ask for it when you call up whoever you get it from...
Old Aug 11, 2001 | 09:05 PM
Rice_Cooker_'88's Avatar
The 40 series does fit onto the thirdgens. i Just put one on and it was a direct fit. pipes exit in the stock locations. it's a crossflow style with the dual outlets. Instead of ordering the american thunder kit from summit, i got the muffler and a 3 inch pipe so i could have the dual outlets. the kit comes with single outlet muffler
Old Aug 15, 2001 | 10:27 PM
Flash84Z28's Avatar
Engine: mild 350
Transmission: TH350
Rice Cooker (love the name) what is the # of the muffler you ordered? Was is the 42583? I'd like to put on my Z. By the way how's it sound?
Matt
1984 Camaro Z28
-'78 350 with Edelbrock 600 Carb, Edelbrock Preformer RPM Air gap intake, ACCEL plugs & wires, 14" K&N filter.
- Eagle Alloys 15" Alum. Rims surrounded by P235/60R15 BF Goodrich Radial T/A's
Old Aug 16, 2001 | 03:56 AM
Tas's Avatar
Tas
all single in / dual out crossflow mufflers are 80 series. www.flowmastermufflers.com
-Tas
'89 Formula WS-6
Super GRK_Taz World
F-Body Dual Exaust
AOL IM: superGRtaz
Old Aug 16, 2001 | 12:28 PM
91RSconv's Avatar
I put in a 40 series flow on my car it has one 3inch inlet and two 2.25" (I think) outlets on opposite sides. Muffler sounds awsome and looks great how it's mounted
Old Aug 20, 2001 | 10:17 AM
Flash: Yeah, the number is 42583. It sounds awesome. now everyone thinks it's a 350!! Only problem now is all the rice can hear it and they feel they have to race some domestics and then get mad when they loose. Anyway, i love the muffler. I have a 3" connecting pipe too, so that helps the sound.
'88 CAMARO 305
OPEN AIR ELEMENT
FLOWMASTER CAT BACK EXHAUST
COMPUTER CHIP
HYPERTECH 160* THERMO.
Frozer!!!
Jan 19, 2024 04:55 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
MintWS6FORMULA
Oct 19, 2015 08:53 PM
hectre13
Aug 26, 2015 08:17 AM
Navy8125
Aug 25, 2015 08:25 PM
