camaros with slp headers ...help
Old Jul 30, 2001 | 10:41 PM
coolj21's Avatar
i have a problem some of my pipes from my headers come very close to the spark plug opening. The only plugs that i can use are Accel header plugs, but they seem to foul out so quickly. Is there any other brand to use besides Accel. All the other known brands like ac delco,bosch come so close to the header that the wire will not go on.
87 IROC-Z 28 CAMARO
5.7 BORED 20 OVER
AFR HEADS, 262 COMP CAM
SLP FLOWBOOSTER
SLP HEADERS
GUTTED AIRBOXES & MAF
FLOWMASTER EXHAUST
DAYTONA TURBO HOOD
SLP CROME SS RIMS
MORE TO COME.
[This message has been edited by coolj21 (edited July 30, 2001).]
Old Jul 31, 2001 | 12:21 PM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
I still have Delco plugs on mine....are you using 90 degree spark plug wires?
92 Camaro RS, LO3, 5-spd, T-tops
Performance:
K&N Open Air Filter, Edelbrock performer TBI intake, Fastchip Prom, Timing +4 degrees, Centerforce clutch, Xact 8mm wires, SLP 1 3/4" Headers (coated), Flowmaster Catback Exhaust, Z28 Grille w/aftmkt fog lamps, MacEwen white-face guages
Electronics:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-846 Amps powering 2 12" Pro Red subs, 2 Pioneer 6x9 and 2 MTX 4x6 speakers.
NEXT UP: TBI mods, 3.42 gears w/Torsen posi
Old Jul 31, 2001 | 06:23 PM
coolj21's Avatar
yes i am using 90 degree wire. delco ran too close to the header pipes. what kind of wires are you using. are the tips as big as msd wires.
87 IROC-Z 28 CAMARO
5.7 BORED 20 OVER
SLP FLOWBOOSTER
SLP HEADERS
FLOWMASTER EXHAUST
DAYTONA TURBO HOOD
SLP CROME SS RIMS
MORE TO COME.
[This message has been edited by coolj21 (edited July 31, 2001).]
Old Jul 31, 2001 | 06:34 PM
mcconahay37's Avatar
I'm using Taylor wires and the plug wires are close but do go on the headers. They were originally angled with a large end, but they came with a bunch of extra boots. I cut the ends off and put the 90* boots on and have had no problems. It's tight, but they go on.
82 Camaro:
350
Erson cam, ported heads,Comp Cams 1.6:1 rocker arms
Edelbrock Performer RPM intake, Holley 600
Crane Hi-6 ignition, Accel supercoil
TH350 tranny with 2500 stall.
Eibach Pro Kit
SLP 1 3/4" headers
Old Aug 1, 2001 | 11:19 AM
Pukka's Avatar
I agree, the spark plug boots are real close to my headers, but they don't actually touch them and I have had no problems.
Old Aug 1, 2001 | 05:10 PM
red350Z's Avatar
Im using accel 8.8mm wires with slp 1 3/4 headers and have plenty of room. the accel wires come with both 90 degree and straight ends that you can bend if there to close
91 Z28 slp headers adj reg accell cap rotor coil comp cam roller
random tech cats flowmaster catback
new motor almsot in
Old Aug 1, 2001 | 11:32 PM
82resto's Avatar
What's wrong with ACCEL header plugs? I've been using them for the past few thousand miles and have no problems whatsoever. Upon recent inspection i have found them to still be in excellent shape, and they're the only ones that fit with my headers.
Jon
89 GTA
Beautiful Gunmetal gray, LB9 305 and T5 tranny. Only 60,000 miles!
Dual cats, 3"flomaster
Accel 300+ Ignition, wires, cap, coil, etc
Airfoil
KN Airfilter
Removed Screens on MAF
SLP 1 3/4 headers
No Smog/AIR system
Old Aug 2, 2001 | 07:04 AM
PROCHARGED89Z's Avatar
Im going threw this crap to.Accel plugs you are buying are not shorties.AFRs are cast to take the gasketed type spark plug.I called the AFR techs and they told me about the shortest plug you can get is a rcy9c Im pretty sure that Part # is right.That is the coldest,it starts at 12.These are champion plugs.You are really stuck here though.The only options you have are to either wrap that tube with Exhaust jackets by thermotech,use headerwrap on the offending pipe,or Jacobs sell ceramic boots to withstand 2000 degrees.I used a boot covering,Ill see how long that lasts,Im using autolites.Call afr they can help you out the best in this situation
Check out my Hompage,or the beginnings of one.355 dynoed at 400HP at 5800RPM & 410LBFT of TQ,on Motorhttp://www.procharged89z.cz28.com/index.html
Old Aug 2, 2001 | 07:55 PM
coolj21's Avatar
Accel has two different sizes, header plugs and regular sizes the difference is about 1/4 of and inch.
87 IROC-Z 28 CAMARO
5.7 BORED 20 OVER
SLP FLOWBOOSTER
SLP HEADERS
FLOWMASTER EXHAUST
DAYTONA TURBO HOOD
SLP CROME SS RIMS
MORE TO COME.
[This message has been edited by coolj21 (edited August 02, 2001).]
Old Aug 19, 2001 | 10:07 PM
racerRoy's Avatar
<font face="Verdana, Arial" size="2">Originally posted by PROCHARGED89Z:
</font>
Hey procharged89z I also have afr heads and i was just on my way to get the short accel plugs. the guy at the store told me he had gaasket type accel plugs. should i check it out or just get the champions? Also did you have to dimple the headers a little or not?
Old Aug 20, 2001 | 09:08 AM
john5.7 87Iroc's Avatar
Car: An '87 Italian Retard Out Cruisin'
Engine: LS1 install in progress
Transmission: 4L60e
Axle/Gears: 9 bolt
I am useing bosch platinums with msd 8.5mm 90 degree wires with no problems with my slp 1 3/4" headers.
1987 Iroc 350
GTS headlight/tail light covers
Camaro SS Wheels w/Sumitomo HTR ZII 275 rear, 255's in front
K&N filters
Adjustable Borla cat back
SLP 1 3/4 headers
w/ Air born coating
3" Catco cat
Large tube runners
ported plenum
Holley afpr
FUTURE GOAL:
To go really F'in fast!!!
Some pics of it at
http://albums.photopoint.com/j/Album...949&Auth=false or (still working on) http://members.cardomain.com/john87iroc
Old Aug 21, 2001 | 02:42 AM
L98IROCZ89's Avatar
Car: 1989 IROC-Z
Engine: 350 Vortech Supercharged ZZ4 TPI
I'm using AC Delco plugs on my L98 with SLP 1 5/8 dual cat headers.
1989 Chevrolet Camaro IROC-Z
L98 - 350c.i. TPI, rebuilt 700R4 auto w/shift kit, Dual catalyst Monza PaceSetter Cat-Back, SLP 1 5/8 Coated Headers, 3.23 Posi rear, Hypertech chip with 160stat, Under-Drive pulleys, AFPR, K&N's, !Air Box w/ Ram Air, moddified MAF, throttle body coolant bypass, Spohn SFC's on order, Alarm, Keyless entry, remote starter, 92 Z28 AeroWing, Brand New Paint (6/21/01)
Future: ZZ4 TPI w/EGR, T56, 3.42 or 3.73, Spohn strut tower brace and LCA's
1989 Chevrolet Celebrity Eurosport
2.8 MPFI, no mods
225,000 miles and still ticking!
More info and pics on my webpage:http://go.to/iroc-z
AOL IMer: GPA 0point0
Old Aug 21, 2001 | 10:22 AM
CamaroMike's Avatar
On my ZZ4 I am using AC Delco Rapid Fire plugs with 1 3/4" SLP headers and have no interference problems whatsoever.
84 Camaro ZZ4 with HOT cam. Ported Heads, Installed Larger Race-Flo Valves, RPM Air Gap Intake, and 1 3/4" SLP Headers (Best 60',Quarter Mile, MPH) (1.88, 12.91, 106.77)
Other Mods: You name it and I have probably changed it.
2001 Dodge Ram Quad Cab 5.9L 4*2
The Bowtie
ASE Certified Auto Tech
LIVE AND DIE BY THE ALMIGHTY BOWTIE!
fonzie85
Exterior Parts for Sale
39
Mar 16, 2016 07:07 AM
evilstuie
Feb 28, 2016 03:33 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
InfinityShade
Aug 22, 2015 08:00 PM
topteam54
LSX and LTX Parts
Aug 11, 2015 07:15 PM
