Hedman Headers...opinions needed
Old Aug 21, 2001 | 10:08 AM
BlackBird305's Avatar
hey guys...well i just need some quick opinions on hedmans...for the most part the install...easy? difficult? otherwise?...i'd really like to get these because of the simple fact that i can get a header w/ 1 5/8" primaries and a 3" collecter w/a y-pipe set-up for 200 bucks...thanks guys
91 Pontiac Firebird...305 TBI
black, t-tops, auto
K&N 14x3 open element flat base air cleaner, 3 inch high flow cat, 3 cat-back into a flowmaster 80 series, IAT Resistor, ultimate TBI mods, 160 stat Hypertech Thermomaster Chip, TC lock-up switch, SLP Torsen Posi w/Richmond 3.73's, removed rear seats, Spohn LCA relocation brackets...SOON TO COME...headers and y-pipe, Nitto Extreme Drag Radials, LT1 Cam, Edelbrock Performer manifold
Old Aug 22, 2001 | 01:55 AM
tacoboy's Avatar
yeah, i like mine, install wasnt easy though...
Old Aug 22, 2001 | 09:40 AM
how tough was it?...time? any speacial fabricating?...thanks dude
black, t-tops, auto
Old Aug 22, 2001 | 11:34 PM
Basett_Racing's Avatar
Mine bolted on with no mods. I did have to buy (2) sets of mandrel bent turndowns, cut them and make a drop down pipe to hook up the exhaust.I did this because the headers dump directly into the tranny X member(if you hads straight pipes that is), I didn't want to let a muffler shop kink, and crimp some because I am running 3" duals. But, all in all, they are pretty good headers for the $$$
82 Z28 383, Ported 215cc Dart Iron Eagle Heads 72 cc Comb. Chambers, Comp custom grind Hyd roller cam, Speed Pro .250" domes, Wheeler Motorsports 4340 I beam rods, Eagle 5140 steel crank, Weiand Team G intake, Holley 830 DP, hedman headers
Trans: Turbo 350 w/ 4000 stall -- Rearend 7.5 w/ Richmond 4.10's, Auburn Minispool
Best ET:11.60 @ 114.56, w/ a 7.34 1/8 @ 93.50, and a 1.622 60'
89 RS, L03 305, Hypertech Chip,cat delete, Dynomax exhaust,K&N open element Filter,160 stat, MSD coil --Trans:700R4 Corvette Servo -- Rearend: 7.5 GM 3.42 w/ posi-lock
Bassett Racing
[This message has been edited by Basett_Racing (edited August 22, 2001).]
Old Aug 23, 2001 | 02:23 PM
tacoboy's Avatar
hmmm took me a long time, probably 20 hrs total...no fabrication but you will probably need a new ac bracket, i have an ac delete bracket on right now, gunna get a header ac bracket someday
Old Aug 23, 2001 | 06:30 PM
TexasLT1's Avatar
Car: '92 RS
where are you getting a 3" y-pipe from? thats the only thing I hold against Heddman is the 2 1/4" ( might be 2.5"?) y-pipe. not that it really matters right now since I still have the stock cat, but I had hoped to be able to upgrade the rest of the exhaust easier and cheaper than it will be now.
nevermind, read message again and saw 3" collector
-'92 RS with self-installed '95 LT1
-Heddman Headers
-TPIS throttle body airfoil
-MSD 6-AL Ignition
Kills
-'97 Mustang Cobra
-'98 V6 Camaro
-'89 5.0 ****stang
-'97 Sebring
-'96 ****stang Cobra
Losses
-'99 Mustang GT
-'96 Mustang Cobra
-'95 Z28 (good race)
-'96(?) Turbo Eclipse (d*mn good race, heavily modified)
[This message has been edited by TexasLT1 (edited August 23, 2001).]
Old Aug 23, 2001 | 07:39 PM
Texas,
since the collectors are 3" the y-pipe starts at 3" so it will bolt up...it slowly diminsishes down to 2.5" though but hey its 99 bucks
black, t-tops, auto
Old Sep 4, 2001 | 01:03 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
My heddmans fit just fine on my IROC. I spent no more than a couple hours bolting them up, although I had removed all emissions equipment before I began, and the passenger header was on the motor when I dropped it in. The only problem I had was fitting the y-pipe under my cast aluminum oil pan. I've got less than 1/8" of clearance so I can't run a clamp. One of these days I'll put a stainless band clamp on, but I seem to get no exhaust leaks so I don't get real worried about it.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
Custom Thirdgen Subwoofer Enclosures
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Sep 4, 2001 | 10:04 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
So what is the size of the exit of the y-pipe for the non-smog headers? The y-pipe is part number 17470
Old Sep 4, 2001 | 10:20 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I think you guys are talking about two different types of hedders - short and long tube. I'd suggest you state exactly which you are talking about. For instance, they don't make a y-pipe for their long tubes.
Frozer!!!
Jan 19, 2024 04:55 PM
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
