Exhaust hitting SSM Subframe
Just replaced all my gaskets, (header and collector pipe) and my gerabox mount to pollyutherane (sp?) and now the exhaust is hitting my passenger side subframe.. I have had to smash my pipe just as it starts going under the passenger side so it clears, but why would it have changed now?
'86 Iroc ZZ4
Best Run 13.8 @ 100mph
I told you to blow the bloody doors off!
The British Firebird/Camaro Site
'86 Iroc ZZ4
Try loosening all the bolts in the exhaust again, and setting a wood block between the pipe and the SFC, then tightening the bolts again. What kind of headers do you have, out of curiosity?
They are Shorty I think they are Hedmann? Will try and do that thanks!
'86 Iroc ZZ4
'86 Iroc ZZ4
Damn poly mount, I did wonder. Thing is the intermediate pipe has already been squashed slightly for clearance if I do any more, I'll probably loose some power. Is ut worth trimming the subframe connector on that side?
'86 Iroc ZZ4
'86 Iroc ZZ4
Trimming the subframe connector may weaken what you have spent money to strengthen. You could replace the poly mount with a new stock one, unless they are repeatedly failing on you.
PS. Don't leave your exhaust pipe dented.
