Anyone here happy with their TES headers???
Old Sep 10, 2001 | 10:34 PM
chevyguy8's Avatar
I just bought these and before I got them I was considering Dynomax since they were cheaper. Then I called and I was told they were discontinued. So after seeing the debate on this board I thought that TES would be the way to go but now Im told how a mistake it was!!
Can anybody tell me that I just didnt waste $340.
I was told that the TPI (one cat) would fit my car, do they flow better than the TBIs?
91 Camaro LO3 RS 5-spd
Open air element,ACCEL 8mm wires w/cap n rotor, K&N filter, flowmaster, Edel. TES Headers(not installed). dual fans.
Old Sep 10, 2001 | 10:51 PM
85 Berl's Avatar
I don't how well they flow in comparison, but I have the TES for the '85 LG4, and I'm very happy with mine. The 305 was scrapped for a 350, but it seems pretty happy with the headers. Mine cost $300 +/- from Summit.
Old Sep 11, 2001 | 12:00 AM
rezinn's Avatar
Hell, Im happy with mine. I got ceramic coated ones with all hardware for $325 bucks, they look brand new.
Old Sep 11, 2001 | 03:34 PM
CobraKiller's Avatar
Car: 88 IROC-Z/00 GTP/05 VUE Redline
Engine: LB9 305/3800 SC/3.5 SOHC V-TEC
Transmission: A4/A4/A5
They're some of the most restrictive headers on the market. Hooker Super Competitions are the way to go or even the SLP shorties. I kick myself for buying the edelbrock exhaust products. Good intakes bad exhaust products...
"Turn a 12 second dream into a 10 second reality"
Old Sep 11, 2001 | 11:28 PM
Dan87IROC-Z's Avatar
I have had no trouble with mine and I think they are some of the best money I have ever spent on my car!
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End with 2.77:1 Gears.
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, Accel High Flow TPI Baseplate, Edelbrock TES 1 5/8" Headers, Catco 3" High-Flow Catalytic Converter, Hooker 3" Aerochamber Cat-Back System, Transgo Shift Kit, Performance Resource Chip, Accel Ignition, K&N Filters, Jet TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET: 14.32 @ 97.7mph
(corrected for elevation)
Old Sep 12, 2001 | 07:22 AM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
I have no problems with mine. I had them ceramic coated (Like everyone should) and I love them. I can't compare them to anyone else though but for me...they did the job I got the TPI ones w/ the 3" collector.
Eric Natzke
91 Firebird 305 TBI
"It Ain't Stock"
http://members.aol.com/j007golden/91firebird.html
For info on certain parts or mods go to the site below
http://members.aol.com/j007golden/modeval.html
Old Sep 12, 2001 | 02:07 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
I'm also happy with mine. I bought TES headers for duel cat model TPI and I also purchased their cat back system. The g-tech pro did show me dropping by a second or a little more in the 0-60 mph time. But I haven't tried any other exhaust systems or headers so I'm probably a little bias. The only thing I hate about them is I eat up collector gaskets quickly.
Old Sep 12, 2001 | 02:23 PM
FlameRedMetallic's Avatar
as long as they are used for a stock 350 or a mild 305 they are great. i love mine. they provided a noticible gain. my little 305 don't need 1/3/4 primaries.
86 IROC-Z
305 TPI
700R4 W/ shift kit
3.23 gears
T-Tops
maroon with gold stickers and rims/ black interior
43,000 miles
flowmaster exhaust, edelbrock headers, gutted airbox, converter, and MAF, K&N filters.
soon to come are 3.73 gears and subframe connecters.
Old Sep 12, 2001 | 04:37 PM
ONEFORMULAOVERALL's Avatar
YES! little tip cut the flanges between the pipes! be care and don't cut the bolt hole also
92 F-BIRd FORMULA T-TOP (WHITEKNIGHT) 5.7L-98,700R4B&MSATURDAY NIGHT
SPECIALTRANS 2500STALL,54MM-AS&M TB-PORTPLENT,LARGETUBRUN,L-98 ALUM. HEADS PORTED
CRANE AFPR,45 PSI,UNDER PULLEYS K&NCOLD AIR KIT,160THERMO,ELDB HEADERS W/3 1/2 Y PIPE 2 RINO CAT 2 4INCH PIPE 2 FLOW,
MSDDIST,6AL,8MMWIRES.
2BLASTERCOIL.ACCELL PLUGS
CUSTOM FASTCHIP BY ED WRIGHT,AUBERN POSI W/ RICHMOND 3.23 AND MOSER AXEL SPLINES CRYGO FROZEN,TUBE FRAME CONNEC
PST KIT.1LE BRAKE KIT! MANY MORE MODS FORESEEN IN MY ERA!13.38ET @ 107.75MPH
[This message has been edited by ONEFORMULAOVERALL (edited September 12, 2001).]
Old Sep 12, 2001 | 06:49 PM
85T\A's Avatar
I like mine the install was not to bad(they fit and bolt right up) getting the last bolt tight is a real PITA!
85T\A 305 TPI Auto WS6 3:43 Edelbrock TES headers Jet Hot Coated,Air Foil,Hooker CatBack,SFC's,STB,AFPR,B&M Mega Shifter Ported Plenum&Manifold,High OutputCoil,Accel8.8,wires,180 deg stst,53000 org miles
Old Sep 12, 2001 | 11:03 PM
IROCET's Avatar
Car: 88 IROC-Z (Sold)
Engine: 5.7L
The best money I ever spent on my IROC was the TES system. At first I didn't know, but after I fixed some vacuum leaks, I am totally impressed with them. Sure they may not be as goo as the SLP's or the Hookers, but I seriously doubt that it is going to make that big of a difference on my car to justify the extra cost of the SLP's. Get them coated, you won't be disappointed. I ued Jet-Hot.
Matt
irocet@hotmail.com
drive.to/Stang_Kilr
88 IROC-Z -- 350 L-98, 700R4, Flowmaster, Edelbrock Headers, Catco Cat, K&N, MAF Sceens Removed, Airfoil, March Pullies, Comp Cams Magnum 1.6 Roller Rockers, Bosch Platinum Plugs, Accel 8.8 mm Wires, MSD 6AL, Hypertech Cap & Coil, Hypertech Chip, Hotchkis Strut Tower Brace
Old Sep 14, 2001 | 01:24 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
I dont know anyone who switched from Edelbrock headers to SLP headers and regretted it. Buts its your money.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Member: SoCal F-Bodies
-=ICON Motorsports=-
Old Sep 16, 2001 | 10:50 AM
Pony Killer's Avatar
Car: 1986 Z28
Engine: 355
Transmission: th400
I had the edelbrock TES on my old 305. They worked well, and didn't rub anything. It was only a mild 305, churning out major top end power was not a factor. the one feature id didn't like was the reductioin to a 2.25" cat. But for that motor they were fine.
I have SLP headeers and Y pipe on the 350, i'll be firing that this week, we shall see how they work
It's always SOMETHING
Old Sep 16, 2001 | 11:15 AM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
If u get the TPI TES's for the 305 IROC they fit perfect and they come to a 3" at the collector. THats the ones I have. The number was EDL-6872 I beilve.
Check the second website in my sig to be sure.
Eric Natzke
91 Firebird 305 TBI
"It Ain't Stock"
redformula88
Oct 14, 2015 06:08 PM
Chad Speier
Sep 24, 2015 12:32 PM
bamaboy0323
Sep 12, 2015 07:14 PM
hdis2002
Sep 8, 2015 02:52 PM
dmtz956
LSX and LTX Parts
Sep 7, 2015 10:16 PM
