Thinking about side pipes, any comments?
Subscribe
Sep 7, 2001 | 10:25 AM
Im thinking about getting sidepipes. This involves removing side ground effects. I was going to put corvette sidepipe covers over them, the paintable ones. Is my idea a waste of time or is it worth doing?
87' Camaro Z28
305 TPI
Stage 2 hypertech chip
Custom ram air w/K&N's
Aluminum Driveshaft
Posi Rear
3" flowmaster exaust
Reply 0
Sep 8, 2001 | 12:50 PM
to be honest I think true side pipe would look funky on a thirdgen. Im working out a plan for site exiting tips right now. my plan is to notch the bottom of the gfx about 4 inches ahead of the back of them, and make a flat, almost rectangular tip for each side. I photoshopped my idea if you want to see what Im talking about.
http://www.geocities.com/the_saint849/index.html
-'92 RS with self-installed '95 LT1
-Heddman Headers
-TPIS throttle body airfoil
-MSD 6-AL Ignition
Kills
-'97 Mustang Cobra
-'98 V6 Camaro
-'89 5.0 ****stang
-'97 Sebring
-'96 ****stang Cobra
Losses
-'99 Mustang GT
-'96 Mustang Cobra
-'95 Z28 (good race)
-'96(?) Turbo Eclipse (d*mn good race, heavily modified)
Reply 0
Sep 8, 2001 | 12:55 PM
They look pretty good, wouldent they melt the ground effects though?
87' Camaro Z28
305 TPI
air foil
shift kit
aluminum driveshaft
posi rear
VST gas ryder gas shocks
custom muffler
Reply 0
Sep 8, 2001 | 01:05 PM
that looks so bad *** !!!! i like it a lot. definetely unique!!!
Reply 0
Sep 8, 2001 | 04:39 PM
nice side exit, what kind of tip is that ? Also, can u get a picture of how the pipes are setup underneith the car ? I've got headers coming in the mail, and im not sure how to set em up.. trying to think of how to do a good dual setup.
Reply 0
Sep 8, 2001 | 05:26 PM
That looks like a NASCAR setup. Cool! What I was also thinking is if side exits could be done like some of the SCCA cars. It would require some sheet metal work and probably the removal of the rear seats, and interior trim. A circular hole could be cut right behind the door, just above the ground effects. You'd have to cut an opening in the floor, and then weld in a sheet metal box(or something similar) to protect the interior from the heat and fumes. The exhaust pipe could then be angled up through the opening in the floor and then through the hole on the side(behind the door, above the gfx). This setup would leave the ground effects untouched, help with ground clearance, and would allow less water in if driving in heavy rain. What do ya'll think?
It's probably too labor intensive and who knows if there's enough clearance underneath? If possible it's probably not worth the cost.
[This message has been edited by coach (edited September 08, 2001).]
Reply 0
Sep 8, 2001 | 07:46 PM
If it would look good to you go for it. Personally I think on a 3rd gen. it would look out of place or just plain stupid. I like sidepipes on old corvettes though so it's not that I don't like that exhaust setup
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
3" Hooker CatBack w/Aero Chamber muffler
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat
3:73 Posi
Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
Reply 0
Sep 9, 2001 | 03:41 AM
wow that side exaust is about 16" long, same as the rim. I had an idea to run a singe 3" pipe to a Y what would spit the dual 2.5" exaust out at a 90* angle. You would then put 4thgen z28 tips under the ground effects right in front of the rear tires. NO muffler but a cat if you have one and IF you do need a muffler get this one on the 3" I pipe
-Tas
'89 Formula WS-6
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
To be installed eventually far far far into the future: Yours if the price is right and I don't have to ship :
Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248), Catco 3" cat, and injector spacer.
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
AOL IM: superGRtaz
[This message has been edited by Tas (edited September 09, 2001).]
Reply 0
Sep 9, 2001 | 07:51 AM
Dont newer mustangs come with sidepipes or something? i swear i saw one with sidepipes. I try not to know to much about mustangs...so im not sure if they came from the factory like that, but if they did maybe a brave soul could actually go up to the thing and inspect how that was done... (but im not doin it, i think they are infectious)
Reply 0
Sep 9, 2001 | 01:07 PM
Roush Mustangs have sidepipes.
-Tas
'89 Formula WS-6
Super GRK_Taz World
F-Body Dual Exaust
AOL IM: superGRtaz
Reply 0
Sep 10, 2001 | 09:35 PM
thanks for the comments, actually it is photoshopped but I was going for the NASCAR look. what I was thinking was using the Spintech oval tubing so that it wont interfere with ground clearance or anything, and then I would custom make the tips out of sheetmetal, and notch the very bottom of the gfx so that it sat right up into them. Im looking at the prices now, and as soon as the money appears Im going for it. h*ll, my dad and I swapped the lt1 in, I think we can probably handle the exhaust.
Reply 0
Sep 16, 2001 | 12:43 AM
i have true duals on my 92 z. it exits right in front of the tires like you are talking about. i have slp 1 3/4 headers and 2 1/2 pipe ran down the outside of the frame on each side of the car. i used 2 chamber flows.ground clearance wasnt hurt that bad. but the worst part about doin it is all driver side shorty headers the collector angles towards the front of the car so that its hard to make the bend to make the pipe go towards the rear of the car on the driver side. you can see a pic of the exhaust when it was on my firebird here: http://hometown.aol.com/bigbadbird355
Reply 0
Sep 16, 2001 | 12:47 AM
o yeah i forgot to say the ground effects hide most of the exhaust with only the tip sticking out right in front of the tire.
Reply 0
Sep 20, 2001 | 03:01 AM
Sounds like what I want to do. I looked at your site the pics don't show anything, got any more? I have Shorty headers too, glad to hear it can be done
'86 Iroc ZZ4
Best Run 13.8 @ 100mph
I told you to blow the bloody doors off!
The British Firebird/Camaro Site
Reply 0
Sep 20, 2001 | 09:05 AM
o my bad dude all my pics of exhaust got deleted by an ex-girlfriend. ill try to take some more.
92 z28 170,000 miles 14.20 on goodyear eagles before exhaust only mods k&n and slp 13/4 headers and dual 2 1/2 exhaust
87 trans am 12.20 on motor too many mods to list
Reply 0
Sep 21, 2001 | 05:27 AM
Cool Let me see them when they're ready! How does it sound through duals? I bet it sounds pretty awesome..
'86 Iroc ZZ4
Reply 0
Sep 23, 2001 | 02:38 PM
TexasLT1... if you were to do this setup, and it looks awesome... I feel bad for ya when you go to get out of the car and its running. You're gonna have the exhaust going right onto your legs!! Also.. if those shaved door handles are real and not photoshopped.. those look awesome too !
Reply 0
Subscribe
