Will These Headers Fit onto my TBI?
Well i am about to buy a set of edelbrock headers from a friend, part #6872, now it says it wont fit on a TBI camaro, yet im guessin its just saying that 2 be technical since its still a single cat and im guessing its the same exact routing, can anybody help me out with this? thanks.
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Edelcrock tube exh.
You probably just need to add the tube for the hot air to the air cleaner.
Transmission: 4L80E/4L80E
The y-pipe has a 3" slip-fit connection to the cat inlet. Your TBI cat inlet is 2-1/4".
Get a direct-fit cat for '86-'90 TPI single cat application while you're at it. Cat-back for same application wouldn't be a bad idea. If you're going to modify something to make it fit, modify your current cat-back to the suggested new cat, not the y-pipe to your current cat.
Car: '89 RS Convertible
Engine: 355
From headers? Sure..it's about the simplest and most recommended start you can make. Probably worth 10-15 Hp (real hp..as opposed to the "I added 50HP when I painted my radiator support black" variety that some guys seem to buy in to).
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
I bought the #6872 headers to replace the #6875 set I had previously(TBI specific) for the larger pipes. I also got a new cat and an SLP 3" catback at the same time. You could really tell a difference in the feel and sound of the car going from 2.25" to 3".
Car: 2007 Corvette Z06
Engine: LS7
Transmission: 6 speed
I gained .6 sec and 5 mph by putting those headers and 3" cat on my TBI car. If you have access to a die grinder, get rid of the air injection tubes that stick like 3/8" into the primarys and you can grind down the bead of weld at the flange/tube junction.
Engine: LS7
Originally posted by DevilsAddvocate
Grinded it off, how should I fill the holes? Get somebody to weld them closed?
Street Lethal
Apr 30, 2019 12:14 PM
