Custom Y Pipe Flexible?
Old Oct 4, 2001 | 12:57 PM
gruveb's Avatar
Car: 1989 IROC-1
I have had trouble finding anybody down here that can do this type of work for me....
I saw at PepBoys that they had 2 1/2 inch flexible exhaust tubing.....I'm thinking, wow, can I fabricate what it is I need to hook up some headers?
Any ideas?
Old Oct 4, 2001 | 02:44 PM
RSS's Avatar
RSS
Some of that bendable exhaust tubing is pretty good stuff but it sure as hell won't pass emissions or inspection. Just get someone to bend some 2 1/2" tubing for you.
92 RS carb'd 350 5-speed T-tops
650cfm double pumper, 3.73's, and a massive cam
Old Oct 4, 2001 | 08:12 PM
gruveb's Avatar
Car: 1989 IROC-1
I don't have any inspections to pass. So if you could get away with it, you'd suggest using it?
Old Oct 4, 2001 | 08:20 PM
firbird's Avatar
LOL i never thought about that, i dont know you would be gettin holes in it every other day and it would be pretty jerry riged but hey its up to you
Old Oct 4, 2001 | 08:33 PM
JETHROIROC's Avatar
As a bona fide Tennessee hick, I can assure you that I've done the flexpipe thing on several vehicles and it sucks. It will be louder and tinny in the vicinity of the pipe, it will rot out quickly, and it will without a doubt leak unless it's welded in good. It should only be used as a quick fix until you can get to a muffler shop, or on a beater (I still retain an 18" flexpipe on one vehicle ). Have a shady shop custom fabricate the y-pipe for you without cats and be done with it. Just my $0.02.
1990 IROC 350
Mods: Too busy trying to make it run right to mod it.
Airfoil, Dynomax cat-back, MSD coil, 180 t-stat, Bald Eagle tires,
Hypertech fan switch, Accel 23# injectors, Holley module, ported plenum,
Ported Daytona Yellow stock base, Moroso valve covers, other stuff,
Streetdampr, Ruger P95DC, hot wife, new oil filter, !cats, !TBC, !AIR.
18.0 @ 85MPH since I'm one big-a$$ MF
"It's better to have and not need than to need and not have."
Old Oct 4, 2001 | 08:48 PM
soulbounder's Avatar
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
Don't buy from Pepboys. Trust me. I work there . . .
Old Oct 4, 2001 | 08:59 PM
gruveb's Avatar
Car: 1989 IROC-1
I can rig something up with the best of them. I don't want to spend the energy on these if they will rot out on me though.
But hey, it was worth asking.
Old Oct 4, 2001 | 09:32 PM
JETHROIROC's Avatar
Maybe I gave it TOO much of a bad rap...if you're planning on getting set up with real exhaust pipe within the next six months or so, you can limp on it, but be prepared to deal with a high potential for noisy leaks that make it sound like a POS. Hell, I've seen the stuff last for almost 2 years , but that's in mild southeast conditions. As a last resort, it's better than open headers!
Old Oct 4, 2001 | 09:34 PM
JETHROIROC's Avatar
Hey, you're in AZ! And here I thought flexpipe was for nothing but Blue-Ribbon swilling bubbas like me. Go for it until you can get set up better.
Old Oct 5, 2001 | 12:03 AM
gruveb's Avatar
Car: 1989 IROC-1
Jethro...if it's good enough for you, then it certainly will work for me. Hey, nothing rusts down here anyhow...
Serious, I think I may give it a try. I am seriously choked off by the stock manifold on there. I have a Weiand stealth intake, edelbrock....can't remember the part number, Comp Cams 12-238-2 all on my L69. No computer junk and when I floor it, the air being sucked in the open element filter is intense.......Exhaust is all I'm short from having a real screaming machine....
Nervous2
Oct 8, 2015 10:53 PM
Eric-86sc
Sep 22, 2015 08:25 PM
Camaro_383
Sep 11, 2015 11:28 PM
Nick McCardle
Sep 10, 2015 08:36 PM
