Bung Hole! on 2055 hookers
Old Mar 10, 2003 | 06:27 PM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
I just got my new 2055 Hooker headers from Jet Hot. I noticed that the bung hole for the O2 sensor is on the back side of the header. I was expecting it to be on the front. Just wanted to check before I started to put them in. Is this correct?
See pic
Old Mar 10, 2003 | 06:28 PM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
The Jet hot looks awsome!
Old Mar 10, 2003 | 06:33 PM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
Old Mar 10, 2003 | 06:35 PM
88GTAinRI's Avatar
From: Ocean State, lil Rhody, the biggest littlest state in the union, Rhode Island
Car: 1988 GTA Black/Gray
Engine: Blown 355
Re: Bung Hole! on 2055 hookers
See pic
Those look SWEET. Damn I wish I had my SLP's jet coated.
Huh huh huh, You said bunghole.
Old Mar 10, 2003 | 07:22 PM
rezinn's Avatar
Why would it matter? What would you do about it if it was wrong?
Old Mar 10, 2003 | 07:31 PM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
I was just concerned about clearance between the o2 and the firewall.
Old Mar 11, 2003 | 12:11 AM
bigals87z28's Avatar
Car: Check The Sig
how much were the headers? nice lookin set man.. im gunna go with out air on my set... im still up in the air on them
Old Mar 11, 2003 | 05:30 AM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
headers were 498 total. From Jet Hot.
Old Mar 11, 2003 | 12:59 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Not a problem. I had to "stretch" the sensor wire a little, but no issue with clearance.
Old Mar 11, 2003 | 11:06 PM
curt86iroc's Avatar
Car: 1990 IROC
Transmission: TH700-R4
wow, ive heard good things about the 2055's but ive never actually seen a set. i must say, im impressed with their manufacturing...at least what i can tell from the picture...especially the y pipe. with my edelbrocks had a y pipe like that
Old Mar 12, 2003 | 09:21 AM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
I think that they are very well made. Have not yet done the install on how well everything lines up, however, I have read several posts that they were was no problems with interference.
Since I will be attaching the shorties to the block before I put the engine back in I don't expect any hassles.
I'll post pics and info after its done..
Thanks five7kid for the info!!
Old Mar 12, 2003 | 06:36 PM
Trans_AM_88's Avatar
Car: 1986/88 Frankenstein Trans Am
Engine: carbed L98
O M F G those look AWSOME!!!
Old Mar 14, 2003 | 12:54 AM
25THRSS's Avatar
how big is the y pipe on the 2055's?
Old Mar 14, 2003 | 05:50 AM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
A nice 3" at the cat end and 2.5 for each y tube.
Old Mar 14, 2003 | 03:18 PM
25THRSS's Avatar
is the hedman y pipe the same size as the hookers?
Old Mar 15, 2003 | 07:38 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
Mine look better
Old Mar 16, 2003 | 05:22 PM
Nasty_Bird_'90's Avatar
are they actual Hookers or are they Jet Hots version? Jet Hot is taking Hookers version of the LS1 headers and making them out of thicker steel with a thicker flange. Just wondering if they're doing the same thing with the L98 stuff now too. They look sweet!
Old Mar 16, 2003 | 06:35 PM
25THRSS's Avatar
Hey five7kid, I did a search and saw where you had opened up the collectors. How exactly did you do this and any sealing problems?
Old Mar 16, 2003 | 08:23 PM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
They are Hookers, they have the Hooker Supercomp PLate on the driver side header.
Old Mar 18, 2003 | 07:51 PM
five7kid's Avatar
I did a fit check of the y-pipe, snugging the down-pipes up to the collectors. That left a mark on the ball flange of the collector. I then too the y-pipe back off, got out the high speed 4" angle grinder, and opened up the hole in the ball flange to the ID of the down-pipes (about 2-1/4"), centered on the marks left during the fit check. Reinstalled the y-pipe, no leak problems (except when the driver's side loosened up on me - no leaks after retightening).
Old Mar 19, 2003 | 12:05 AM
25THRSS's Avatar
I think ive decided i'm gonna go with the 2055's and do exactly what you did. The only thing I dont want are the air tubes. Can I just cut them off and weld the holes shut and then grind the weld down to make it look smooth again? Thanks for the info five7kid! Oh and by the way, why only 2 1/4, I thought the y pipe was 2 1/2 to 3 inch? Thanks again
Old Mar 19, 2003 | 12:11 AM
five7kid's Avatar
You can do that to the A.I.R. tubes if you like.
The downpipes are 2-1/2" OD. That translates to right around 2-1/4" ID. Opening up the ball flange to the downpipe OD wouldn't increase the flow area.
Old Mar 19, 2003 | 12:22 AM
25THRSS's Avatar
Sorry, but I guess i'm a little slow, lol, but what does OD and ID stand for???
Old Mar 19, 2003 | 05:46 AM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
od= outer diameter
id = inner diameter
Old Mar 19, 2003 | 03:18 PM
25THRSS's Avatar
od= outer diameter
id = inner diameter
thats what I thought, thanks. So the hookers really only have 2 1/4 inch pipes?
Old Mar 25, 2003 | 05:25 AM
25THRSS's Avatar
See pic
I'm not totally sure why it faces the back. I think it is for clearance reasons so the O2 sensor will fit without problems, but I'm not totally sure. Anyone else know?
Old Mar 25, 2003 | 08:14 AM
five7kid's Avatar
Unless specifically stated otherwise, everybody lists their pipe sizes by OD. So, actually flow area is a function of OD minus wall thickness for the actual ID (which will change, depending upon tubing gage, obviously).
Old Mar 25, 2003 | 09:28 AM
FyreLance's Avatar
Car: 00 TA, 91 Formula, 89 RS
:hail: Nice Looking Headers :hail:
Old Mar 25, 2003 | 05:14 PM
25THRSS's Avatar
Thanks for explaning everything to me. I really appreciate it and learned a lot too. Thanks!!!:hail:
Pac J
May 17, 2020 10:44 AM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
no green
Jan 9, 2016 09:22 PM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
drumstixer
Sep 29, 2015 03:02 PM
