Has anyone ever tried/ will it work ????
Old Mar 11, 2003 | 06:07 AM
70GTO's Avatar
Car: 89 Iroc Z
Engine: Carburated 427 Smallblock
Transmission: 400 Turbo
I am wanting to run 3" Dual exhaust on my 89 Iroc , however none of the muffler shops in my area want to mess with anything above 2 1/2'" unless it's a prebent system.
I'm wondering if you could take a pair of prebent intermediate pipes "such as the ones from dynomax" & run them side by side & if they would still fit in the factory exhaust channel under the car "for ground clearance"?
I know that I will still have to fabricate from the long tube header collectors to the beginning of the int. pipe " not running any cats" and modify the whole muffler & tailpipe system after it makes its way past the rear axle, which I think I can achieve, but at least this way you would have the pipe assembly past the rear axle "which seems to me like the largest pain of the whole process".
What do ya all Think???
Would it work or has any one tried or done it????
Give me you opinions guys, besause I'm still scratching my a$$ on what to do other than go with a single 4" system.
Thanks Guys, Bruce (70GTO)
Old Mar 11, 2003 | 11:53 AM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
Take some measurements. If you did do that i would run some bullets and just dump it.
Terrell351
Jun 13, 2021 01:13 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
Jk_Under
Aug 17, 2015 03:08 PM
Fronzizzle
Aug 17, 2015 02:52 PM
