Installation troubles
Old Mar 16, 2003 | 09:40 PM
Falcon3's Avatar
If you've read my previous post about talking my dad into getting headers, I've almost done it. The only thing he's worried about now is the installation. I've done some searches but never come up with what I want.
When taking off the old manifolds, how probable is it that the bolts break? How much clearance is needed? How expensive is the Ypipe? He won't let me get duals.
If I could get some testimony on this one, I'd REALLY appreciate it.
Old Mar 16, 2003 | 10:28 PM
KNTA4DNU's Avatar
Car: '97 Z28
Engine: 5.7
Transmission: M6
My manifold bolts came out easily. If you look at the heat shields between the manifold and the spark plugs, you will see the manifold bolts go through the shield, and a small tab of metal bends up alongside the bolt head. I suppose this is to keep the bolts from backing out. Bend the tab back so you can get a socket on it and away you go. My manifold bolts were rusted to the shield, and though they came loose from the head ok, it twisted the heck out of the shields, but they're going in the garbage anyway. Just be careful with the one the oil dipstick tube is attached to. I had to rig a new bracket.
With no air condtioning and the A.I.R. plumbing tied out of the way I could easily slide the headers in and out on each side of the engine.
Tell your Dad to put on some old clothes, order a pizza, and just like everything else you do, double your time estimate and go to it!!
Old Mar 16, 2003 | 10:31 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
Just spray some type of rust eater on the bolts the day before you start the install. Spray the bolts about every 4-5 hours. They should come out with no problem. I'm not sure what headers you are installing but for the 305 I am assuming you are putting 1 5/8" on there. I didn't have any clearance problems with the SLP headers.
Vintageracer
Jan 10, 2020 05:33 PM
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
toronto formula
Nov 10, 2015 06:17 AM
djmarch
Aug 19, 2015 12:07 PM
86IROC112
Aug 17, 2015 07:57 PM
