Do all 2210 Hookers come with slip tube?
Old Mar 16, 2003 | 11:24 PM
Camarokid01's Avatar
I found some Hooker 2210s online but in the picture it doesnt have the slip tube that I see on everyones on here? Did they make 2 different ones, if so whats the difference?
Thanks in advance
Old Mar 16, 2003 | 11:35 PM
JMatlock88's Avatar
Car: 1991 Formula
Engine: 355 DFI Superram w/ R-Trim
Transmission: Probuilt 700r4
Not that I'm aware of! In either case, you want the slip tube. The starter would be a pain to replace without the slip. Dont worry, it rarely leaks or causes problems.
Old Mar 16, 2003 | 11:40 PM
Hey thanks for the fast reply, looking closer at the picture I can see it does have a slip tube. Do you know if Polyurthane mounts will make the headers clear things better or worse? Thanks again
Old Mar 16, 2003 | 11:43 PM
JMatlock88's Avatar
Car: 1991 Formula
The poly mounts will make them clear worse. They raised my motor about 3/4 inch. I can show you exactly where to grind if you get me a picture of the back side of a kmember. The grinding even with the poly mounts is minor.
Old Mar 17, 2003 | 12:01 AM
Would new rubber mounts make it better? Should I just leave the old factory ones in? about how much did you have to grind off the K-member? Is it worth it to be able to keep the poly mounts? Thanks for the fast reply again and sorry for all the questions.
Old Mar 17, 2003 | 12:10 AM
By the way your car is bad ***, what cam (specs) are you using in it?
Old Mar 17, 2003 | 12:17 AM
JMatlock88's Avatar
Car: 1991 Formula
You should replace the mounts if you have the engine out. It's cheap. The rubber vs. poly can be debated. If you are making power or plan on making power, I'd use the poly. If you are just a stocker or mild bolt on guy, then you just need rubber mounts. The poly mounts introduce a little more vibration. You must prepare yourself to handle that, but it's not as bad as I imagined it would be.
There is about 6" of grinding about 1/8 inch deep to get the headers to clear perfectly. If you can find me a picture, I can help you more.
No problem.
Thanks! 224 224 560 560 are the @.050 specs. It's a retro roller comp cams extreme energy custom grind.
Old Mar 17, 2003 | 12:33 AM
Old Mar 17, 2003 | 12:47 AM
Old Mar 17, 2003 | 01:08 AM
JMatlock88's Avatar
Car: 1991 Formula
Umm...I think I answered everything already. Let me know if there's something else.
Old Mar 17, 2003 | 01:21 PM
Hey sorry about that it double posted those 2 posts, I was having computer problems so I guess it enterd them twice. What size rockers are you using? I am about to put in a 242 248 540 562 extreme energy cam and put 1.5 rockers on it. Thanks again for all the help
Old Mar 17, 2003 | 01:45 PM
JMatlock88's Avatar
Car: 1991 Formula
That's a huge cam... I hope you have some cubes! I'm using Crane Race Gold 1.6 RRs. No Prob!
gixxer92
May 18, 2017 11:20 AM
jrdturbo
Mar 31, 2016 02:58 PM
no green
Jan 9, 2016 09:22 PM
FormulasOnly
Oct 2, 2015 05:52 PM
zman1969
Oct 1, 2015 11:09 AM
