Catback- Weld or bolt???
Old Nov 4, 2001 | 06:41 PM
Hg's Avatar
Hg
Car: '87 Z
Engine: 355 in the works
My catback should get here this week, I was wondering what you guys prefer, welding or bolting the catback together? I would weld it but I don't have the tools, and if you need to take it apart later you don't have to ruin $300+ catback by cutting it apart. What do you guys suggest?
Old Nov 4, 2001 | 10:48 PM
NTChrist's Avatar
Weld. It'll keep the cat-back intact longer. You also don't have to worry about the clamps hitting the ground, if ground clearance is a problem.
If you can find a good exhaust system, it's still pretty cheap. Expect to pay $15 to $20 per round.
No guts, no glory.
Old Nov 4, 2001 | 10:55 PM
Trent257's Avatar
yea weld it if you can, even if you do have to remove it, you can always weld it back together, if you have to
Trent
---Car---
89 Firebird/305 L03 TBI A4/t-tops
Open Element Edelbrock Aircleaner w/ K&N air filter/Summit Chrome Valve Covers
Edelbrock TES headers 3" out/flowmaster American thunder 3" exaust/Catco cat
---Stero---
Pioneer DEH-P730 Premium
Infinity 2way 4652 4x6's/Pioneer 4way ts-a6985 6x9's
profile cl640 110x4
Old Nov 5, 2001 | 11:08 AM
Ray87Z's Avatar
Car: 94 Z28
Engine: LT1 w/ headers, catback, CAI, tune
Axle/Gears: 3.23s
I didn't weld up the cat-back on my 87Z (hooker aerochamber) and everything it's been fine for over a year so far. No problems.
Ray87Z
-Vortec headed 350.
86 IROC w/ a cammed 305 TPI.
Formerly Ray86IROC.
www.inter-scape.com/Ray
Old Nov 6, 2001 | 03:07 PM
Jza's Avatar
Jza
Weld it. Much cleaner installation. What reason would you ever have to take it apart? It's not in the way of anything under the car. If it was, simply unbolting it from the cat should give you room for pretty much any job under the car. For the fuel pump or any related job, you'd just unbolt the two hangers and the whole thing would pull right out the back of the car.
Old Nov 6, 2001 | 04:44 PM
Hg's Avatar
Hg
Car: '87 Z
<font face="Verdana, Arial" size="2">Originally posted by Jza:
Weld it. Much cleaner installation. What reason would you ever have to take it apart?</font>
I need to be able to take it apart because I'm gonna have to replace the fuel sending unit, it doesn't read the fuel level anymore. Maybe I'll just do the sending unit first then put the catback on. I think I'll bolt it together then just have some shope do welds on it, it couldn't cost THAT much since I already put it in...
Old Nov 6, 2001 | 04:55 PM
85transamtpi's Avatar
My hooker system is all clamped on. It doesnt leak or move so what's the difference? It is only one spot over the rear anyway (and on the muffler) so its not like you can see it easily. My vote goes to clamp for ease of possible repair. I cant really see how one could manipulate the system too much with just the cat disconnected.
I guess if you are obsessive then go have it welded up, otherwise I think clamps work fine.
peace
Old Nov 7, 2001 | 09:10 AM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
I've always replaced my own exhaust at home with clamps, but the first place I drive is to a muffler shop to have it welded up.
-Rich-
F-body driver
Mar 6, 2023 11:44 AM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Lanz06
Sep 14, 2015 07:16 PM
Jlanz55
Sep 6, 2015 07:28 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
