Help// Header Question
Old Nov 13, 2001 | 04:36 PM
Bluebird's Avatar
Car: 1991 Pontiac Firebird
Transmission: 700R
Edlebrock TES Headers for my 91 Firebird!
The shop is installign them and there
is a problem.
The problem is the heater pipe is resting against the header on the passenger side,
which the guy says will get hot and melt the hose and cause the car to possibly overheat.
also he says on the drivers side the header will rest against the steering knuckle, which
could melt the plastic of the knuckle, and will probably rub against the header..
is there some aftermarket pipe that will allow me to re-route the water pipe up and over and tie into the hose above..
and what bout the steering knuckle.
Old Nov 13, 2001 | 08:39 PM
Chevy83Z28's Avatar
That should be the mechanic's problem not yours, he's the one that took the job on to begin with. But with the heater hose, there should be some way to tie the hose or maybe to possibly shorten it (to cut out some slack?) to prevent that from touching the headers. The steering knuckle... I dont know what to do. Also make sure the spark plug wires don't touch the headers!
Old Nov 13, 2001 | 10:31 PM
Bluebird's Avatar
Transmission: 700R
well if it were just hose, but it's hose
up at the top, but then it goes into a
metal pipe.
the mecanic is going to fix it when
he finds out exactly what is neeeded.
that is the problem.. He is gonna
call edlebrock first thing in the morning
cuz technically, these edlebrock headers are madee for this year car, and these problems shouldnt even be an issue if they are "designed to fit" but, it is aftermarket stuff so I expeect some probs.. I know people on here have the edelbrock tes headers.. I would like to know if any of these things were issues on your guys cars????
Old Nov 15, 2001 | 10:09 AM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
He could eliminate that metal tube on the passenger side. It's tough to get at, but it could easily be replaced with a tee-fitting and some more heater hose.
-Rich-
Old Nov 15, 2001 | 09:13 PM
Bluebird's Avatar
Transmission: 700R
ok he calleed me today to tell me
he was able to move the tube about 1/4"
and he said the Headers cleared the
steering knuckle.. he said he pre-measured
it and according to measurements, he thought
it wasnt going to fit, but when he got it
in it workeed fine..
Old Nov 15, 2001 | 10:36 PM
Fred91TA's Avatar
Car: 1991 Trans Am
Transmission: 4L60
<font face="Verdana, Arial" size="2">Originally posted by Bluebird:
</font>
How much did you get charged for the install?
91 TA 5.7 TPI Automatic
w/WS6 and 3.23 rear.
K&N Cone Air Filter (at the end of the plastic tube), Hypertech Coil, Moroso Blue Max Wires, Bosch Platinum plugs, JET 180*fan switch, JET air foil, Dual cats with Flowmaster 3" cat-back, GM Performance PROM, Complete PST components on front suspension, Spohn LCAs/Panhard bar.
My car only uses Mobil 1 synthetic fluids.
Old Nov 16, 2001 | 10:25 AM
89 CamaroIROCZ's Avatar
I used to be a mechanic and i don't see how you could "pre measure" the space hwere the header is going to go. Its easy enough to just take the manifold off and pop the header down there no problems. I hope he isn't going to charge you too much for the job.. hopefully only about 100 bucks or 2 hours i'd say. Maybe a little more
Matt
89 Camaro IROC
350" GM Crate Motor
278/290 .476/.494,
3000 Lockup Converter,
..plenty more
Harwood 2" Cowl
UNITED WE STAND
beastin91rs
Oct 9, 2015 07:38 AM
hectre13
Sep 8, 2015 03:38 PM
tricky1
Aug 23, 2015 01:17 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
