going true-D....whats out there besides supercomps?
Car: 92 RS/90' vette
Engine: Heads/cam/miniram/blah blah blah..
Transmission: T5/700!
Axle/Gears: 3.08
just wondering...i need a longtube 1 3/4 header.
1990 RS
V8/A4
White/Primer ....Project in the works
1998 Z28
M6/!cags
MTI lid w/k&n
Magnaflow catback
HPP
Underdrive pulley
78 Chevy Fullsize
355 11:0:1
Trickflows, 282/282 .580/.580,, supercomps,torquer, holley 700 DP
Big Bad Sleeper
**Previous Rides**
1990 RS
1985 Berlinetta
1990 RS
V8/A4
1998 Z28
M6/!cags
MTI lid w/k&n
Magnaflow catback
HPP
Underdrive pulley
78 Chevy Fullsize
355 11:0:1
Big Bad Sleeper
**Previous Rides**
1990 RS
1985 Berlinetta
I just had a bad experience with some headers that supposedly were for my 91 formula 305 tpi that did not fit at all. I have to send them back and get some new ones.
How hard are long tube headers to install compared to shorties. Is there a certain procedure that should be followed. I would like to use long tubes, as I'm going with dual exhaust anyway. However, if they are a pain to put in, I don't want them--I haven't driven my car for almost two months. I am sick of driving my mom's astro van
to and from college each day. I want something easy to install and if long tubes fit the bill, then all the better.
to and from college each day. I want something easy to install and if long tubes fit the bill, then all the better. Last time I was on the web site, I saw Hooker long tubes w/ 1 & 1/2" primaries - in addition to the 1 & 3/4" ones that I bought.
1986 IROC, fully loaded, Mini Ram'd 383, Art Carr 700R4, Accel DFI, 12 bolt rear, etc, etc......
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
<font face="Verdana, Arial" size="2">Originally posted by cort351w:
I would like to use long tubes, as I'm going with dual exhaust anyway. However, if they are a pain to put in, I don't want them- ... I want something easy to install and if long tubes fit the bill, then all the better.</font>
Hooker has some intermediate length headers with 1-5/8" primaries and 3" collectors.
-Tas
'89 Formula WS-6
305, TBI, 700R4, P.A.W. 14x3 open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips, Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248)
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
-Tas
'89 Formula WS-6
Super GRK_Taz World
F-Body Dual Exaust
I put Hedamn headers on my 84. I don't know if they are intermediate or long, but the pipes extend just past the tranny bell housing. Took 10 hours, and had to jack up the engine to get them past the block.
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
If you go to Headman's website youll find a 1 3/4 full length but its more expensive,need more modification to fit and takes longer to get compared to the Hooker SC Long Tubes
Daz
Daz
Car: 92RS
Engine: LS 402 inwork
Transmission: TH350
Axle/Gears: 10 bolt,3:73's
If you don't mind almost having to pull the engine all the way out then you probably don't want the Hooker Super Comps. I had my motor out when i installed mine. It was easy to install them once i started lowering the motor back down in the hole!!! They are GREAT headers.
White 92 RS,388 cu.in.N/A
3.73 gears,auburn posi
Best 60 ft : 1.97
Best 1/4 : 12.679
Steve Spohn
Rear Suspension
Autometer guages
Extremely Loud Stereo !
Driven Daily
installed motor with AFR's and my Hooker L/T's
Kansas F-Body Association Member
Best 60 ft : 1.97
Best 1/4 : 12.679
Steve Spohn
Rear Suspension
Autometer guages
Driven Daily
Car: '87 IROC
Engine: LT1 350
Transmission: 700-R4
I have a set of super comps, they were easy as pie to install for me. Just remove the starter, and install the headers from the bottom...pretty simple. It also helps that I don't have the huge AC box in the way :-). I did have to do a little bit of massaging to the k-member and A-arm to get the headers to sit without touching metal, but nothing a cutting wheel and 10 minutes couldn't take care of. (The drivers side is a direct bolt in, I didn't have to do anything special there)
