Hooker SuperComps (LT) and O2 sensor?
Car: 1991 Formula
Engine: 355 DFI Superram w/ R-Trim
Transmission: Probuilt 700r4
You can get it to fit, just pull more of the grey wire out of the loom. My O2 bung is in my mufflex ypipe a few inches after the collector. If you cant get it to work, the only thing custom involved would be a soldered wire splice with some heat shrink and extra loom. You're going to have to move your knock sensor to the other side. Same thing applies.
Car: 1991 Formula
True. I bought the female end that matched the 3wire heated O2 sensor that I bought. I didnt have to extend the factory O2 wire. I just removed it from the loom more and swapped the pins into the new 3wire plug. The other two wires were simply switched power and ground of course.
Single wire O2 here. Enough wire in the harness from the factory to reach bung in the collector. So far haven't had any issues. Goes into closed loop and stays. Even in 30 degree weather. I do have a heated O2 for backup if I start having problems.
ambainb
Apr 25, 2016 09:21 PM
RyanSS
Jun 4, 2001 10:54 PM
