Flamethrowers
Flamethrowers
Ok, Ok, don't rip me a new one for posting this. I know its a bit dated but I think it would be really cool to have flamethrowers on my Camaro. So how do you do it? I remember someone used to have a kit to do it but I don't think any flamethrower setup will work on a car with a cat and I have to keep mine
. Won't any unburned charge ignite in the cat? Hey, I'm gettin' a cat-back and a cut-out too so I'm not a total loss
. 2 ways to do it. Full straight pipe (no muffler, no cat) with small diameter pipe. This keeps velocity high. You then run the engine very righ with lots of fuel and put some sparkplugs near the exaust outlet to light the raw fuel up. This is the old school way to do it.
New way has propane sprayed into the exaust with sparkplug or something to light it off.
-Tas
'89 Formula WS-6
305, TBI, 700R4, P.A.W. 14x3 open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips, Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248)
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
-Tas
'89 Formula WS-6
Super GRK_Taz World
F-Body Dual Exaust
Propane. OK, sounds good, ( hey the treehuggers can't whine- propane burns clean
) does anybody sell a kit? How about a website or somethin'? Can't wait to have the only flame-spewin' car in town
! Banned
Car: 4 Mopars total
Engine: Pentastar power
Transmission: T/F and New Process
Axle/Gears: Three 8 3/4's & one 9 1/4
Well, you gotta remember to not melt the rubber bumper on the rear of your Camaro. It would be cool though.
1983 T-top Trans Am. All stock (for now) LG4/auto/3.73 posi. 70,000 original miles. SLOWLY going through a Knight Rider conversion. (it will be done one of these years)
Bset of 15.79@86mph 2.16 60ft
1963 Dodge Dart drag car. 360/904/4.88
Best of 10.94@120.44mph
YEAH! Someone else thinks their cool! Anyway, your right about the bumper, when I get my cat-back setup I wanna get some tips like FiReBReTHa's and make sure they extend out just enough to keep flames away from the cover, might fab some little heat shields too. But I'm getting carried away, I'm still not exactly sure how to do this.
Yeah Ok, I hadn't thought about those little bottles, thats a good idea. But I'm still not sure how to do it. Obviously, I need a way to switch the gas on/off without walkin back to the trunk. No way I'm paying for one of those nitrous bottle openers for this. Wiring up some plugs would be easy, probably should weld fittings to the exhaust pipes. What kind of lines should I use to pump propane into the pipes? Hardline will probably crack. I'm going to build a little box to contain the bottle, venting it outside the car ( maybe I'll hide in the "glove box" ). I want to work out a way to do this cheaply and safely- don't want to turn my car into a bomb! However, BBQ pedestrians and wildlife are not my problem
hehe.
hehe. Trending Topics
"Full straight pipe (no muffler, no cat) with small diameter pipe"
A freind of mine's suburban had a true dual setup like this, 2" pipe with nothing but glasspacks, and even exiting behind the rear wheels it'd shoot about 5-6 inch flames out the tips when he'd rev it real high and let off. It didn't do this at first, just after about 2 months when the 'packs wore in, or out depending how you look at it. Also you could only see it at night.
88 Camaro (The mighty LO3 SC!)
305TBI/700R4/2.73/125,XXX miles
10" Open Element and Flowmaster 80 seires
Bosch Platinum plugs
Double silicone Accel wires
Next up: headers and gears
Try here www.hotrodsofnorco.com they sell kits for flamethrowing hot rods of norco if the address is wrong would what to put in your search
if you do it without the propane, you can't just run it rich, you need to have a carburetor, a manual choke and something to ignite the plugs, I've seen grill ignitors before. (your car can't be equipped with a catalytic converter to do this either.) you rev the motor up and pull the choke and then hit the ignitor, thus- flames out the back, as you can imagine its kinda rough on the motor, the gas kinda washes down the cylinder walls, and leaves deposits on the plugs- other than that its really cool.
1987 Camaro SC
ZZ4 350
Demon 750
2000 RPM converter
3.73's
Outlaw Z-28 cowl
1987 Camaro SC
ZZ4 350
Demon 750
2000 RPM converter
3.73's
Outlaw Z-28 cowl
Car: 1992 Camaro RS
Engine: 406 SB
Transmission: TH350
Many ways to do it, I'm thinking about it myself...
Here's two more sights with pics and info on it:
http://flamingexhaust.cjb.net
http://hammer.prohosting.com/~backwood/buick.html
Car: 1992 Camaro RS
Engine: 406 SB
Transmission: TH350
Here they sell kits for all types of cars, including fuel injected ones.
http://www.tailpipeflames.com/
SWEET! I'm gettin' one of those kits for fuel injected cars. Their only $80! Anybody have one of these kits installed, the website says that they are complete but they still don't say how they work ( but claim it doesn't effect computer or cat ). I wanna find out how they work before buyin' one.
Hmmm... Nobody on here seems to have flamethrowers already. Guess I'll just have to call that place sometime. Anyway can't wait to see my cat-back and flamethrower kit under the Xmas tree
. Supreme Member
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
my friend has a 94 Z and he is gonan try this out on his piece ranger
he is gonna put gas in the windshield wiper housing and have a line run back to the the pipe and ignite it
lol
might work....but who knows
lol
Car: 91 Red Sled
That last idea is dangerous. I wouldn't run fuel in any flex line for more than 12" besides. Have fun putting out the fires.
Just thought I'd make this easy for you guys with TBI: Rig a cable, door lock solinoid or something to the TPS sensor. If you flip it without moving the throttle blades the ecm will pumpshot and you'll run rich. Play with it and you can get it to run rich enough to make flames. You could rig a quick switch that bypasses the TPS sensor so the ecm sees WOT, you guys get the idea. It's what I plan on doing.
, Jon (350 TBI!)
91 Red My website
, Jon (350 TBI!)
91 Red My website
yea, jprevost, you use the AUXillary on your remote to control a relay to control the kit, easy, thats my plan,
body before flmaes, but firebretha, must have fire.......
and thanx for the compliment, the tims extend enough so no worrys on melting.
91 FireBird 305 V-8
Edelbrock Catback, Custom Alarm. Fourth Gen Console. i have six cupholders. all for starbucks!
Go|)Created The Earth, And Then Turned Up The Bass.
Here's My Audio Install!
"Honda's FOR ME TO POOP ON!" -Triumph...
91 FireBird 305 V-8
"Honda's FOR ME TO POOP ON!" -Triumph... I saw a T/A that has flames running from the manifold all the way through the pipes. Looked really cool, but I don't think it was the effect he was going for. For some strange reason, he was dumping fuel straight into the manifold.
Car: 91 Red Sled
This is my plan to do it for under $50:
Use my old undercar neon (crap) power inverter which is 9000v, plenty to jump the spark plug gap in a tail pipe. With that hooked up to switch I can flip it on and off real easy. I'll just tap into my crappy tailpipe with the spark plug, no problems with leaks since it's after the muffler.
Then I'll rig some sort of old manual choke cable from a junkyard or old bicycle to flip the TPS sensor on my holley TB unit. I could probably just design some circuit but that would be too expensive. I'm going for cost here and all this is free for me since I already have the neon power inverter
, Jon (350 TBI!)
91 Red My website
, Jon (350 TBI!)
91 Red My website
um, ,pics i wanna see what you did....
depends on how close its shooting...
91 FireBird 305 V-8
91 FireBird 305 V-8
"Honda's FOR ME TO POOP ON!" -Triumph... funny, i've always wanted to do this since high school and completely forgot about this mod. i was really into it, but never knew how to set it up safely. now, a few years later, i stumble into this, funny how people think, hehe...
i'm glad to see that they offer kits for this, YEAH!!! hopefully i'll throw on a set, and post pics.
'86WS7
Ram Air...
*EiyseWhite*
'86WS7
Ram Air...
*EiyseWhite*
