about to order exhaust..
Old Apr 8, 2003 | 08:45 PM
trans_am_ta_84's Avatar
Car: 89 trans am
Engine: 355
i'm about to order the hooker cat back for my 89 trans am and.. i don't know what engine code i have.. can someone tell me which one i order? i have the 305 fi LO3 my vin number is 1G2FW 21E6K L2119 21 if that helps.. which one?
66-16823 Hooker Cat-Back Exhaust System, 1986-1992 Camaro/Firebird (Engine Codes G, F, 8) - Does not fit Dual Cat Cars
$259.99
66-16820 Hooker Cat-Back Exhaust System, 1983-1992 Camaro/Firebird Non HO (Engine Codes H & E)
$259.95
66-16822 Hooker Cat-Back Exhaust System, 1983-1985 Camaro/Firebird (Engine Codes G, F, 7)
$259.99
Old Apr 8, 2003 | 09:27 PM
LastViceRS's Avatar
Car: '91 RS
Engine: LO3, For now...
With the L03, you have engine code E. The eighth character denotes the engine code.
But - that doesn't mean you necessarily have to use the catback for that application. If I'm not mistaken, I believe 66-16820 has a 2-1/2" intermediate pipe, and the other two have a 3" pipe. 66-16822 used to be around $200, but apparently they were selling too many of those. BTW, if you find it cheaper, it comes with a 4-bolt flange which can be cut off and a piece of pipe spliced in its place. Hope this helps...
Old Apr 9, 2003 | 06:17 AM
Car: 89 trans am
Engine: 355
so if thats true about the 2 1/2 pipe could i order one with 3in pipe? if so, which one of the other 2 can i order?
Old Apr 9, 2003 | 10:01 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
They all have 3'' I pipe. The only difference is the cheap one has a rectangular 4 bolt flange that hooks to the cat. I ordered that one, had it cut off and welded up.
Old Apr 9, 2003 | 12:32 PM
Car: 89 trans am
Engine: 355
and let me guess.. the cheap one is the one i need?
Old Apr 9, 2003 | 02:23 PM
Car: 99 Formula
Axle/Gears: 342
Look at the cat on your car, if it has a 4 bolt flange at the end that hooks to the stock I pipe , then yes, but I don't think you do.
Old Apr 9, 2003 | 09:01 PM
Car: 89 trans am
Engine: 355
ok thanks mark... i am in love with the sound of hookers =) your car sounds beautiful
Old Apr 9, 2003 | 09:32 PM
Car: 99 Formula
Axle/Gears: 342
Wait till I post a new sound clip next week.
Fireslash
Apr 11, 2016 06:43 PM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
jaridjohn
Oct 5, 2015 07:01 AM
Bigold4x4
Sep 28, 2015 05:21 PM
