SLP headers
Old Apr 15, 2003 | 09:55 PM
Blown87's Avatar
Car: 87 Z-28
Engine: 383 HSR w/supercharger, AFR heads
Transmission: 700r4 w/2500 stall
Axle/Gears: 3:73
SLP headers
I installed SLP 1 3/4 ceramic coated headers on my 87 Z-28 today. Before I installed them, I read that many people have clearance issues with the steering shaft and SLP has suggested replacing the motor mounts. I went ahead and replaced the motor mounts before installation. I used Energy Suspension polyurethane mounts. Replacing the mount was very difficult, but look at how much room I have between the header and the steering shaft. Hope this helps anyone having clearance issues.
Old Apr 15, 2003 | 10:05 PM
Mike89GTA's Avatar
Yup, I put new stock type mounts in with my new engine and have about that much clearance too.
Old Apr 15, 2003 | 10:16 PM
MikeS's Avatar
They look good. For the record, I've got about a third of that much room with original motor mounts.
Old Apr 17, 2003 | 03:22 PM
LeftTurn1LE's Avatar
I still have my original motor mounts. The headers don't rub the steering shaft, but I had to tilt the engine to get the drivers side header in. Also, the header pushed my brake line over which caused it to carve a groove into my steering shaft. I had to move the line over a bit.
Old Apr 19, 2003 | 11:26 AM
quadgoat's Avatar
Car: 1992 Firebird
Engine: Stealth Rammed 412 with TC78 Turbo
Transmission: '93 T-56
Axle/Gears: 3.27 9 bolt posi with PBR discs
Hmm, that's interesting, because when I put my new 350 and 6 speed in I used ALL Energy Suspension mounts (motor and tranny) and my steering shaft does hit on my SLP 1 3/4" headers. Only when I turn left though, and only the first revolution of the steering shaft, if I'm makin a TIGHT left and crank the wheel around a couple times the shaft hits only the first time, and only on the fat part (shaft is kind of oval-ish shaped, flat on two sides, rounded on 2 sides) I dunno if anyone else has had this problem or not, but I'm trying to decide if I want to grind down the shaft a little bit (it just barely hits) because it has rubbed my Jet Hot coating off the header tube where it hits Anyone have suggestions on if it's smart to grind on the steering shaft?
Thanks,
-Paul
Old Apr 20, 2003 | 08:58 PM
19WS6T/A91's Avatar
mine did the same thing... only rubbed when turned to the left. all i did was loosen up all of the steering column bolts under the dash and moved the column over towards the pass. side. it gave me almost 1/2" clearance from the header. i would try doing that before i would gring on the shaft.
Old Apr 20, 2003 | 09:02 PM
quadgoat's Avatar
Car: 1992 Firebird
hmm, moving it toward the passenger side gave you more clearance, huh? I suppose that makes sense since it would pivot at the joint where the column comes out of the firewall? I will definitely try that because whoever had the car before me shifted the column all the way to the left, away from the passenger side (no idea why! ) so I will definitely give that a shot! Unfortunately the Jet Hot is already rubbed off in that one spot oh well, such is life I guess!
-Paul
Old Apr 20, 2003 | 11:29 PM
MdFormula350's Avatar
cant wait to get mine and install them, i am going to get a new o2 sensor and depending on how the gaskets look in the install kit i might have to buy better gaskets.
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
redformula88
Oct 14, 2015 06:08 PM
Nervous2
Oct 8, 2015 10:53 PM
TX-SleeperC5
Sep 24, 2015 03:13 PM
alpine247
Sep 16, 2015 05:25 PM
