Cat question
Car: '86 Camaro
Engine: LG4
Cat question
I need some clarification on what cat I would need to go from my y-pipe(3") to either a Hooker or Flowmaster catback. I'm under the impression that the ends of the I-pipes attach to the cat via a flange, so the universal cats won't work without cutting and welding. And the direct fit cats have AIR tubes, I removed the AIR system. Would it be ok to just cap off the AIR tube on the cat or thread a pipe plug into it?
Thanks in advance.
-Matt
Thanks in advance.
-Matt
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
if you removed the A.I.R. system, you must not have emisions to worry about, why not just run a test pipe instead of a cat.
Car: 1984 Z28 Camaro
Engine: H.O. 355 NOS
You know I think he should do that too, but I don't think they can sell them "Test Pipes" any more. Thats why a lot of guys gut their cats. You can't even get a muffler shop to make one up for you. Big fines I guess
Auggie
.Auggie
Car: 2002 Formula Firebird
Transmission: 4l60e
No place will do it for you if you ask them "HEY will you put a pipe in place of my cat????"
Get the catback, then take your cat off and role in open headers. They wont let you leave like that. They will stick a pipe in place for you no questions asked. They cannot let a car come out without anything BUT if a car comes in with a cat it leaves with a cat.
Car: '86 Camaro
Engine: LG4
Well, we do have emissions, basically just a sniffer test and a gas cap test, no visuals whatsoever. If your car is 96 and newer, they don't even do that, just go off of OBD2 somehow. Anyway, I want to keep a cat on it. So blocking off the AIR tube is okay, that answers my question.
Thanks,
-Matt
Thanks,
-Matt
Car: '84 Berlinetta
Engine: ZZ4
Transmission: BTOD stage 3
Axle/Gears: 3.23 posi disc
You can also search around for the right shop, I had a test tube custom bent for me to connect the y pipe to the hooker cat back. I think it cost me $35 from an import shop none the less. Those sneeky import buggers....
If you don't have to have it, loose it. Thats my opinion of cats. Im more of a dog person anyways
