Has anyone ever cut the inner contents out of an EFE valve on an LG4 or L69????
Old May 8, 2003 | 10:02 PM
330hp_91RS's Avatar
Car: 91' RS
Engine: Built 355
Transmission: Probuilt 700r4
My EFE valve started making a horrible noise once so I had to pry the valve and stick it so it's open all the time, not controlled by the thing on the intake.
The butterfly is not straight up and down, kind of angled, it's restricting flow.
Has anyone every cut the entire butterfly out? I am no longer using the CC intake and carb, so I have no choice. I know I could get a whole new set of headers but I don't want to spend the money. Is there any other alternative?
Old May 8, 2003 | 11:09 PM
Berlinetta00's Avatar
Veteran: Marine Corp
Car: '84 Berlinetta
Engine: ZZ4
Transmission: BTOD stage 3
Axle/Gears: 3.23 posi disc
Take it out and replace it with straight pipe and doughnut gaskets. I had to do that when I put on my edelbrock headers. Just make sure you get the right size pipe and gaskets, and you should be fine. Mine has never leaked in the six monthes its been on there.
Old May 9, 2003 | 09:31 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
As I recall, the L69 and the TPI manifolds are the same size (larger than the LG4). One difference, aside from the driver's side heat stove, is that the TPI manifold to y-pipe is simply a spacer, no donut required. I've got one lying around the garage, I think. If you want it, let me know. It's yours for shipping.
JamesC
Old May 9, 2003 | 02:28 PM
330hp_91RS's Avatar
Car: 91' RS
Engine: Built 355
COOL!
JamesC
So you have a spacer that will fill the gap between my header collector on the passenger's side and the y-pipe? Awesome? I would guess that fully packaged it would weigh like 4 pounds, so I'll figure out what the shipping is, and I'll send you the cash.
What is your ship-from ZIP?
Old May 9, 2003 | 02:42 PM
JamesC's Avatar
330hp,
Let me get home and check to see that the spacer is still around (as you can see in my sig, I swapped in the L69 exhaust, though the pass side manifold, along with the spacer, came from a TPI car). I'll pm you later today.
JamesC
Old May 18, 2003 | 04:26 PM
330hp_91RS's Avatar
Car: 91' RS
Engine: Built 355
Got your PM...
330hp,
JamesC
How did you find that part #? Is it stamped on the spacer? I tried looking it up at gmpartsdirect.com and it didn't come up. Are you 100 percent sure it's the right part that I need?
Do all the 85-88 LG4's and L69's have these spacers? If they do I can just head over to the pick-a-part and pick one up. But of course if you already have one laying around, and it is what I need I'll just send you a few $$$ for shipping.
Old May 18, 2003 | 04:49 PM
JamesC's Avatar
330hp,
The part number comes from the 1982-1991 Chevrolet Camaro Parts & Illustration Catalog CD--if you don't have it, you need it. The LG4 and L69 are equipped with EFE, thus the butterfly, but the TPI cars simply had the spacer--essentially the same part fabricated without the butterfly. You might take the part number to a local dealership. Surely, they can order what you need. However, you're still welcome to the one I have. By the way, finding one at a bone yard would probably be easy enough, since, I believe, every TPI Camaro/Firebird, had one, but dropping the y-pipe to retrieve it would be a major PITA. Simply buying one might be a whole lot easier.
JamesC
Old Sep 3, 2004 | 03:30 AM
SSScottSS's Avatar
I hate to bring up an old subject like this, but does anyone have the part number for the spacer mentioned above? which goes where the efe valve was? or, if you have one and would be willing to part with it plz feel free to PM me.
Thanks in advance
Old Sep 3, 2004 | 10:10 AM
JamesC's Avatar
I believe that part # is as follows: 5234327 Spacer, Exh C/Ovr Pipe.
JamesC
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
CarGuyDennis
137
Dec 6, 2016 11:02 PM
xxblade31
Sep 21, 2015 01:36 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
