catalytic convertor = fire?
Old Jul 10, 2003 | 06:44 PM
Fastbird's Avatar
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
How close can a catalytic convertor be to the floor boards before it causes a fire (without heat shields)?
I have a Mufflex y-pipe with dual cats and it awfully close to the floor boards. The driver's side pipe routes under the trans crossmember, goes through a cat and then comes together around 2 feet after the trans crossmember.
I know I should get the fuel and brake lines out of the way and I will but the cat is about 1" or less from the floor pan. Should I be worried about that?
Old Jul 10, 2003 | 09:45 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
i hardly doubt that the car will catch fire. the floor pan is made out of similar materials as the cat. your passengers feet may get a little warm but i wouldn't worry about any spontanious combustion.
Old Jul 10, 2003 | 11:06 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
I don't think you have to worry about a fire.
Old Jul 11, 2003 | 05:56 AM
level's Avatar
Car: 1987 transam
Engine: 383 /w superram
Transmission: 700r4 /w 2800rpm stall
not sure if 3rd gens are the same. but I had an old buick and the heat shield for the starter fell off and the carpet caught fire I had to **** on it
so just make sure the catalyc converter has a heat shield..
Old Jul 12, 2003 | 12:13 PM
TekViper's Avatar
Car: 1990 Pontiac Firebird
Engine: 3.1L v6
Transmission: Automatic
lmao u took a **** on a fire in your car?? i dunno if i could manage in a panic situation like that. thats hilarious.
Old Jul 12, 2003 | 03:41 PM
Soulrev's Avatar
Car: Formerly - 87 T/A, 87 Bird.
ROFLMFAO! :hail: :hail: :hail:
Old Jul 12, 2003 | 05:09 PM
Trans_AM_88's Avatar
Car: 1986/88 Frankenstein Trans Am
Engine: carbed L98
BAAAAHAHAHAHAHHAHAHA :lala:
Old Jul 12, 2003 | 05:46 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
i always carry a fire extinguisher in my car.
IMO EVERYONE should carry one. regardless of what they drive.
Old Jul 13, 2003 | 12:41 AM
jfreeman74's Avatar
Car: 1985 Iroc-Z
:sillylol: Now that's being able to perform under pressure.
Old Jul 13, 2003 | 11:32 AM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
wow, i bet that smelled good, how long did it take to get that stench out?
Old Jul 13, 2003 | 02:23 PM
level's Avatar
Car: 1987 transam
I wouldn't know I sold the car it was an old pos buick lasaber 1980 or close to it... heavy *** car I never did any work to it. the front ball joint went out in a mcdonalds parking lot to that was alot of fun fixing
RS Reaper
Oct 17, 2018 07:52 PM
PurelyPMD
May 5, 2016 04:57 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
indygene
Sep 26, 2015 11:21 AM
89fast5oh
Sep 8, 2015 09:55 AM
