Plugged Convertor?
Old Jul 13, 2003 | 01:20 PM
AT4 T/A's Avatar
Car: 1989 IROC-Z
Engine: L98 350
Transmission: New 700r4 Done by 11/14/07!
Plugged Convertor?
I know my convertor is kindof jacked, cuz it does rattle a little bit inside. My question is would it cause a slight hesitation or stumble once it gets hot if it's obstructing the exhaust? I'm trying to pinpoint that problem and I've already put new cap, coil, rotor, wires, and plugs on her. Still, it stumbles a little after getting to temperature.
Old Jul 13, 2003 | 07:08 PM
guza's Avatar
Car: 1985 Berlinetta
Engine: 305 4BBL
I had a plugged cat a while back. Didn't cause a stumble. You couldn't tell it was plugged till you tried to get on it. After about 2500 RPMs it would fall on its face. The motor sounded like it was trying to do something but I got slower and slower.
Old Nov 8, 2004 | 07:08 PM
1984Z28HO's Avatar
Car: 1985 iroc
Engine: 305 H.O.
Transmission: 5speed
Axle/Gears: 3:73
if you cat is ratteling take it out and remove the inside of it with a happer and chissel, then put it back in.....it will sound nice and give you some more power...
Old Nov 8, 2004 | 07:10 PM
1984Z28HO's Avatar
Car: 1985 iroc
Engine: 305 H.O.
Axle/Gears: 3:73
sorry in better english you want to remove the ceramic mesh that the inside of the cat is made out of.....
wigmobile
Feb 26, 2025 02:56 PM
gta892000
Aug 11, 2019 11:16 AM
92rsvortec350
Sep 10, 2015 10:54 AM
Jlanz55
Sep 9, 2015 09:09 AM
89 formula TPI
Sep 7, 2015 11:06 AM
