burn valves when OpenHeaders?
Old Jul 24, 2003 | 06:16 PM
yanfoo's Avatar
Car: Malibu 80, T/A 87, S-15 87
Engine: 267 Bu, 305 T/A, 350 S-15
Transmission: Auto Bu, 5spd T/A, Auto S-15
I'm installing my headers this week-end, 2210 hooker.
I told my friend after i go back to my house with open headers, he told me not to, that it will burn my valves!
Then i told him, why do dragster go open headers?
he told me they can because they got stiffer valve spring.
So what!? my headers are longtube, so there far from the block.
I know you'd burn valve with no manifold at all, but should i be ok?
I will have to travel for 1hour on the Highway to get back home.
I cant install the exaust on it, since i dont have the mufflers yet.
my car is manual, if thats of any importance, due to the loss of low-end torque... as little as it might be.
Thanx, im doing this Satursday, id like an answer before that heheh , if its not good to drive it this way, i'll call for a tow-truck (my friend father has one, would make a good price for me).
Old Jul 25, 2003 | 12:45 AM
MouseCamaro305's Avatar
burning the valves? no, he's close though, you may "warp" the valves due to the cooler air being able to access the valves a lot quicker, because of the fact that it doesn't have to travel through a warm exhaust system. rapid heating or cooling causes the metal to warp, it shouldn't hurt the valves if you don't regularaly drive around with the pipes open, however, to be on the safe side why not stuff a rag inside the header pipes when youre done driving.
BTW- valve springs really have nothing to do with the valves warping.
Old Jul 25, 2003 | 01:08 AM
25THRSS's Avatar
there was a post about this earlier, read it.
Old Jul 25, 2003 | 07:45 AM
bigals87z28's Avatar
Car: Check The Sig
if i could make the BS flag any bigger... nothing will burn the valves... your friend is a dumb jackhass. If so, i must of burt the ****e out of mine when i ran my car w/o exhaust. Warping the valves is just as possible as burning them. NO cold air is gunna travel up the headers, into the chamber, and somehow cool the thousand degree explosion that makes internal combustion work. So unless you are putting a torch on the valve, you will be fine.
Old Jul 25, 2003 | 07:02 PM
yanfoo's Avatar
ok then, i'll install thoses headers tomorow
Old Jul 25, 2003 | 08:32 PM
25THRSS's Avatar
Old Jul 25, 2003 | 09:19 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
You plan on driving an hour with open headers? You do realize its INSANELY loud right? Any cop you pass by who doesn't pull you over must really be apathetic about his job. I had my car idle (keyword: IDLE) with open headers in my drive way once and my friend 3 miles up the road heard it while he was inside his house.
Old Jul 26, 2003 | 10:45 AM
Car: Check The Sig
werd, and i have a 305!! i looked down the street, and saw about everyone from about a 3-4 blocks down were in the street, saying wtf?
Old Jul 26, 2003 | 11:54 AM
91RS5speed's Avatar
Car: 91 RS
Axle/Gears: Auburn Pro / 3.42
I drove mine around with open shorties for a week and everythings fine. I think with longtubes you wont have any problems
Old Jul 27, 2003 | 06:57 PM
yanfoo's Avatar
well, there not "in" yet.
On the Driver side, i've cut a bit with torch to give good clearance, then bolt it, seem fine , exept for 1 brake line too close, but that brake line is touching on the passenger too, so i'll put a NEW one, and route it so both side is good...
on the passenger side, using the origninal big started is asking trouble, its so close, i'll look for a small starter, bit will keep it this way until i get one (i want to get a scrap one and rebuil it), then on the passenger side, it seem the first tube is TOUCHING the frame thing (the big one under the engine) so we will heat it red and kick it *** with a big hammer then 1/4 " further it will clears.
otherwise, some scratch on the coating, but anyway i choose the coating so they dont look all rusting quickly.
Old Jul 27, 2003 | 07:03 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
the only way you will hurt the valves is if you run with no exhaust at all.. ie, no headers or manifolds.
otherwise, you will be fine..
ps: open headers will be loud..... if you finish installing them at 1am, be sure to wake the neighbors.
Old Jul 27, 2003 | 10:25 PM
ES87iroc's Avatar
Car: 1987 Camaro Z28 IROC-Z
Engine: 5.7L TPI
Axle/Gears: 3.42:1
Open headers on my car sounded like ****. Wayy to raspy. Anyways, for anyone else thinking about doing headers, it's much easier if you unbolt the motor mount on the driver's side and jack up the motor. Piece of cake then to get that header in.
Old Jul 28, 2003 | 02:14 PM
Car: '89 IROC-Z
My stock starter wouldnt fit at all it hit in multiple locations. Driver's side header fit without touching anything but the passenger side is a HUGE pain. The slip-tube hit the a-arm mount (where you described) and I had to move my brake line because the header was squishing it. What I did was I took the bracket thats inside the fenderwell where the hard line meets the rubber hose and moved it over to the left. This gave me more slack in the hard lines so I could move it upward and out of the way ...Its still close though so I wrapped it with heat wrap.
Old Aug 1, 2003 | 09:27 PM
Dan88IrocZ's Avatar
Go ahead and smack your friend upside the head as hard as you can. I'm really beginning to hate all the retarded little car myths. Smack him hard, twice actually
I ran open headers on my car for a couple days and it was INSANELY loud, but open headers with a heavy lope sounds amazing. Hehe...I loved it. Don't get used to all the extra hp though...you'll feel a decrease in UMPH once you bolt up an exhaust. :lala:
F.I. 57 Belair
Aug 23, 2021 01:09 AM
db057
Apr 28, 2019 07:45 AM
92firebirdguy
Sep 1, 2016 07:53 AM
sandman92084
Sep 12, 2015 10:27 PM
Glowsock
Sep 11, 2015 11:09 PM
