2 1/2 Duals
Car: Camaro
Engine: Gas
Transmission: Automatic
2 1/2 Duals
Home made, but looking good
The rear end still has to be painted, as you can see, but otherwise I'm very satisfied
Car: 1989 C4
Axle/Gears: 307
Good job! Thats the same exact routing I had on my camaro, except I had a little extra room in the cat location where I could bolt on a truck dual in & out converter for the Denver smog ***** and I had glasspacks at the end. Be carefull though I smashed the tube over the axle on a hard launch and had to use air shocks from there on.
Second look not exactly the same I had em piggy backed but still a good job.
Car: Malibu 80, T/A 87, S-15 87
Engine: 267 Bu, 305 T/A, 350 S-15
Transmission: Auto Bu, 5spd T/A, Auto S-15
im wondering if doing an "H" pipe in there would have been a good idea? somewhere around the cat spot.
Yea that looks very sweet. All tucked up nice an tight, nice bends too Instead of putting in an H pipe I'd try ta squeeze a X junction in there somewhere. I'm putting together a dual set up in the near future I hope I'm crafty enough to pull it off . Do you have any sound clips a that badboy?
